Results 1 to 2 of 2
Thread: Propeller Diameter Question
11-09-2024, 11:14 AM #16000 RPM
- May 2001
- Maine
- 1,039
- 7
- 40
- 55
- 199
If everything was to remain constant with a boat set up on a STV Euro with a Sportmaster for example, what would be the gains/ pros or losses/ cons in going from a 14.5" diameter to a 15" diameter propeller? Would the propeller design play a large part in the results? I am thinking about just a Mercury stock cleaver or perhaps a ET.
11-09-2024, 07:09 PM #2
A larger diameter prop if everything was equal, SHOULD reduce the slip number a bit. It could reduce the amount of RPM that you could turn also. Remember, all of the information about propellers is kind of black magic. Every set up is different. You just have to try different options to see what works best. Carter Powell
Propeller Diameter question
By 4Speed in forum Props, Setup, and RiggingReplies: 1Last Post: 12-13-2015, 06:17 PM -
Propeller Diameter ?
By Topo in forum Props, Setup, and RiggingReplies: 1Last Post: 04-03-2004, 07:14 AM -
Prop diameter question
By vector mike in forum Technical DiscussionReplies: 12Last Post: 10-23-2002, 08:16 PM -
Merc Gearcase Diameter Question
By Greg in forum Technical DiscussionReplies: 6Last Post: 08-30-2001, 07:17 PM
