Results 1 to 1 of 1
    Sitka, Alaska
    2002 280 ROS drop on powerhead with 1piece exhaust adaptor $10,000
    Only selling because we’re doing more cruising now and moving down to a 225 promax.
    I had this built by Bob Garone @ Marine 2000 in NY.
    All std nic bores, wizard pistons, ROS box, 1” intake spacer.
    injectors just cleaned.
    After break in, only ran on redline. 62 hours on rebuild. Compression written on heads.
    Will come with the exhaust plate, tuner and bosh pump.
    Would consider partial trade for a fresh water mint 225 promax w/ 2 piece exhaust plate, tuner.
    Motor is located in eastern Washington
    call , text, 509-429-79two eight or PM me.
    Attached Thumbnails Attached Thumbnails IMG_3401.jpg   IMG_3400.jpg   IMG_3398.jpg   IMG_3395.jpg   IMG_3394.jpg
    Ron Pratt
    '91 Virage "The LAST Virage" 15" 280
    26' Grady White "fish getter"
  1. Mercury Tech: 2.5L Powerhead-to-Adaptor-Plate Gasket Question for Exhaust Chest cut to 225
    By mikes bad habit in forum Technical Discussion
    Last Post: 03-17-2022, 10:36 PM
  2. Replies: 5
    Last Post: 02-01-2018, 09:19 PM
  3. Need 2ea sbc 1piece seal crank pto adaptor using flywheel
    By jetfiremuck in forum Parts Wanted
    Last Post: 11-25-2016, 02:02 PM
  4. Replies: 6
    Last Post: 05-18-2016, 09:45 PM
