Results 1 to 9 of 9
    May 2006
    Lake Carmel Ny, Jamaica Bay
    Inline 6 lower on a v6?
    Buddy bought a basket case , 200 efi powerhead on offshore mid with appears to be an inline 6 lower. I have inline 6’s and it sure looks the same. 8 spline. Do inline 6 lower bolt up to v6’s or does he have some kind of performance lower with a smaller bullet
    Love is a paycheck
    Apr 2023
    Long island, NY
    It's probably a 4 1/4" gearcase from an XR4. 1.78 gear ratio.
    TX......somewhere?
    Quote Originally Posted by revlimiter776 View Post
    they will but tha front stud has ta be removed (gives it away) best i remember... also tha drives shaft is a tad shorter.. we use ta use those coned and cut down ta 16 inches on tha early V6 before merc brought tha good (better) factory stuff out.....
    like said, probably XR4/6... tail of housing will tell which one without takin' it apart...tail of matin' surface same length as cav. plate it will be tha 4.. if its a little shorter than cav. plate it will be tha 6.... is it coned?
    Pekin, IL
    The inline will bolt up but the shift shaft will not. Used to run an xs85 (2.3:1) on a 200 back in the very early 80's. Shift shaft was off-set by about half an inch which was easy to accommodate. Problem is they don't hold up to the power very well.
    Rock
    Team Junk
  5. Likes OnPad, David - WI liked this post
    May 2006
    Thanx man
    Love is a paycheck
    May 2006
    It is coned
    Love is a paycheck
    TX......somewhere?
    It is coned
    if i was guessn' i'd say its tha XR6 case... XR4's and/or inlines don't last long at all.... jmo.
  9. #8
    Lake Coochiching, Ontario
    My old XR4 apparently lasted a long time with the second owner who did not surface the lower unit. I blew up 3 or 4 XR4 lower units surfacing them.
  10. #9
    TX......somewhere?
    Quote Originally Posted by David View Post
    thats a killer for 'em..
    had good luck with tha 6's, surfaced and start in gear...
  1. WTB Inline 6 2:1 lower unit.
    By at100plus in forum Parts Wanted
    Last Post: 06-01-2020, 03:44 PM
  2. Mercury Inline Lower
    By Mrzip in forum Misc. Parts and Accessories
    Last Post: 09-28-2018, 03:19 PM
  3. inline lower
    By xskid1 in forum Lower Units
    Last Post: 04-13-2014, 11:35 PM
  4. Inline xs lower unit
    By SAMMY CORLEY in forum Technical Discussion
    Last Post: 02-17-2009, 06:13 PM
