Results 1 to 10 of 10
    May 2001
    Maine
    Never had this happen before...
    With less than 10 hours I went to remove the fuel filter and it separated. Looks like some pretty cheap/ thin plastic...
    Yes, its a OEM Mercury part as I never install aftermarket.
    Yes, I backed off the set screw prior to removal
    Yes, I lubricated the O-rings when installed.
    Never seen this in 16 years of winterization.
    May 2001
    Maine
    I found one of my old filter boxes and according to the picture it looks like there are 6-8 webs connecting the threaded top of the filter to the main body. The Mercury/ broken one I installed only has 4. It will be interesting to see what the new one has.
  3. Thanks David - WI thanked for this post
    Likes David - WI, sonicss33 liked this post
    Jan 2020
    Pinole, Ca
    All 7 I have on the shelf (OEM) have 4 webs. Never seen one break like that and I have used both aftermarket and OEM
  5. Thanks David - WI, 4Speed thanked for this post
    May 2001
    Maine
    The more I look at the Quicksilver box, it probably only does only have 4. Couldn't believe what a new Mercury one cost... just over $70.
    I wonder if the filter had swollen as once I unscrewed the top, I had to pry a little around the sides/ edges of the filter and place a pair of needle nose pliers in the center hole and pull them apart so as to "break" it free.
    Apr 2023
    Long island, NY
    Any chance you got a NOS that has been sitting on someones shelf for 30+ years? Plastic gets brittle over time and not made for ethanol way back then.
  8. Likes Greg G liked this post
    ...they're giv'n em away on e-bay...
    May 2001
    Maine
    I saw them on eBay but figured I would support the local Mercury dealer and I was in the middle of the winterization process and didn't want to wait, but will plan better next year as $70 vs. $10-$15 is a tuff pill to swallow. Where it was difficult getting the filter body out out after the top separated, I am thinking it probably broke when I was removing it... I was thinking a possible ethanol issue also. I don't think it was a self life issue as the dealer moves a lot of inventory as they sell several boating manufactures.
    I will say as a test that the new one went in much easier than the broken one did when I screwed the top back in. Installing the new one I only needed to use the special wrench for the last 1/2 to 1 turn, when screwing the old top back in I had to use the wrench for the last couple of revolutions.
    Jan 2020
    Pinole, Ca
    Yeah and don't put them that tight. Once the oring goes down in the bore it is sealed...it doesn't need to seat against anything real hard. I just put them in till the top seats and looks like its all the way down. I don't put them in like a fastener or a pipe fitting.
    Being a "water seperating" filter... I wonder if long term exposure to water in the filter causes the plastic to swell a bit? Some plastics do.
    Trump!
    May 2001
    Maine
    Good point. I drain both sides of the filter housing (Optimax) into a clear plastic bottle and let it sit for a day or too and haven't seen any water. I wonder if Mercury Stabilizer or QuickClean could have weakened the plastic as the manual calls for 2 teaspoons of each in the housing then run at idle for 5 minutes... Anyway, its been issue free for 16 years - probably operator error on tightening like 25 mentioned.
  14. Thanks David - WI thanked for this post
    Likes David - WI liked this post
  1. Don't let this happen!
    By Mark75H in forum The Scream And Fly Lounge
    Last Post: 11-13-2008, 10:35 PM
  2. I said it would happen and what did happen?
    By The Big Al in forum The Scream And Fly Lounge
    Last Post: 12-14-2006, 10:10 PM
  3. Don't Let this happen to you!
    By jimbob1 in forum General Boating Discussion
    Last Post: 09-14-2006, 12:11 PM
  4. Just what I said would happen!!!
    Last Post: 08-26-2006, 07:16 PM
