Results 1 to 13 of 13
    Oct 2006
    Emory TX
    What prop and speed on your vector?
    And what hp?
    Did you mess with the pad?
    1986 Tahiti Warrior rude 4.0 v8
    1976 Skeeter Odyssey rude 235 sold
    92 18' Mirage Jaguar xr4 sold
    HydroStream Vector 200 efi
    Jun 2018
    Floating around
    That’s a question for captain Insaneo who doesn’t seem to be posting much these days so I will offer what I remember. He runs a 15” mid right on the transom zero set back with Hoss Triton 1 choppers. He has multiple pitches. The hull is 100% as pipkorn built it so the hook and concave are still there. Runs well over 100. I’m running a Vking and so far the hoss triton 1 28p I sourced is by far my favourite prop. Really nice combo. I have a 200 banging close to 90 now but still working the set up it’s not getting all of it just yet.
  3. Thanks hydroViper235 thanked for this post
    There were a couple Vectors on the "top guns" list at hydrostream org... they were supposed to list the prop, engine & mods (I think): https://web.archive.org/web/20051014...rg/TopGuns.htm
  5. Thanks hydroViper235 thanked for this post
    Jun 2018
    Floating around
    Can’t go wrong with a lightning et for these hulls. Everyone who has one loves it and runs huge numbers. They are known to chuck blades though. Some guys say cleavers will run the hardest if you’re really pushing the limits. The set up there is about 1.5” above pad with perfectly neutral trim then the air lifts the bow. I know a dude who runs his king over a hundred with this set up. I haven’t personally seen it yet because he’s one of those guys with a dozen speed boats and he runs other stuff but I have no reason to not believe him. I’m simply nervous offering second hand advice that’s heresay so I offer these qualifiers in case you try it and it sucks lol no money back guarantee in this advice
  7. Thanks hydroViper235 thanked for this post
    Oct 2006
    Emory TX
    It's so expensive to experiment!!!
  9. Likes LakeFever, skialot2 liked this post
  10. #6
    Oct 2006
    Emory TX
    What do you think about 14x30 3 Blade Cleaver 6 inches setback 300hp
  11. #7
    Aug 2021
    Osteen/Deltona, FL
    That's a lot of weight on the back of a Vector.
    83 Vking 150 Mariner 2.5L
  12. Likes scott reierson, David liked this post
  13. #8
    Oct 2006
    Emory TX
    Heck yeah it is
  14. #9
    May 2001
    Madison, WI
    1973 Vector (23"hi transom). Stock bottom. Daily use 26 Hill Yamy drag or 28 ET Lab (both props stk out of box) 3"back. 15" Mild Mod 225 PM with 34CC heads. 200 GC Bobs "shorty cut notched" LWP. Prop shaft 1"above +/_.
    Lots of setup work and weight balancing. Big #no problem. Not for amateurs. Easy 90 in 800-ft w/20,22 24 Yamy drag props. Violent. Calm water boat only. Will bite and hurt. Core and transom must be done. A Drag style setup seemed to be much safer for big number. Generates highly spirited driving experiences.
  15. Thanks hydroViper235 thanked for this post
    Likes hydroViper235, LakeFever liked this post
  16. #10
    Oct 2006
    Emory TX
    Suggestions?
  17. #11
    Jun 2018
    Floating around
    Really depends on your goals. Setback increase porpoise and vectors porpoise a lot. If you want to just run hard a short mid mounted right on the transom is the way to go imo. Play with props to your liking. If you buy used and don’t damage them if you want to sell they hold value so it’s not hard to play with a budget. A 15” set up is going to cost you though. If you want to stick with a 20” I’d aim for the least amount of set back you can and if a hot speed machine is your only goal save the money and weight and get a manual plate. If you want some passenger options a power jack makes sense.
    Prop wise my feelings are small ear choppers will bring the best bang for the buck and work well on that hull. I’d avoid large ears at least big pitch ones that will push you into that crazy area. Cleavers I dunno, on v hulls some love em, some hate em. Et props either merc or Yamaha drag probably best bet.
    Horsepower wise? 300 is a ton for a vector. You’re going to need clanking balls to spool 300hp up to the max on a vector with a big pitch prop. I’d cringe to think how fast that peak speed would be. Most likely more than that hull can safely go imo. Vectors have a lot of lift. A good 200 with some compression is going to put you easy 90-100 once dialed in. Especially if you really tighten up the heads and run race gas that thing will move out like crazy with a 200 fishing motor. Plenty of us 200 fishin motor guys happy with the performance. If it ain’t enough you can always sell and add more. I like to take things in stages that’s my method. If your looking for a go big or go home approach a good 260 will do all you need and then some imo.
    be careful. Core, transom, all must be tip top for this type of caper
  18. Thanks hydroViper235 thanked for this post
    Likes hydroViper235 liked this post
  19. #12
    Oct 2006
    Emory TX
    Quote Originally Posted by scott reierson View Post
    no!
    Never mind, I saw your previous post
  20. #13
    Nov 2018
    Central Pa
    i ran mid 90's with a WEAK 200 and a 28" et cut chopper. no need to mess with the pad on the vectors they're pretty decent as is, just make sure they're not all banged up and that the core and transom are strong
  21. Thanks hydroViper235 thanked for this post
  1. Vector speed
    By largecar91 in forum Technical Discussion
    Last Post: 11-11-2021, 03:59 PM
  2. Vector 200 top speed
    By rdkvector in forum General Boating Discussion
    Last Post: 05-04-2010, 03:54 AM
  3. 74 vector top speed
    By casey850 in forum General Boating Discussion
    Last Post: 09-19-2009, 08:22 AM
  4. hull speed on hydrostream vector?
    By Bigjohnsons in forum Technical Discussion
    Last Post: 10-31-2006, 05:13 PM
  5. Need More Speed for Vector
    By bclongdrive in forum Props, Setup, and Rigging
    Last Post: 08-10-2004, 12:49 PM
