Results 16 to 30 of 37
    Oct 2005
    savannah,ga
    I'm following this thread too. Very interesting.
  2. #17
    Jul 2004
    Connecticut
    Quote Originally Posted by aj06bolt12r View Post
    Cool but.. Way too heavy for only 200HP that is not tunable like a SHO and I'm assuming it has the same Sportmaster as the new v8 Mercs? So gigantic and has to be run way out of the water?
    I know that weight is without oil.. But is it without the cowl and without a prop too? I bet it is.
    Mercury has not posted an accurate scale weight in decades. 300R had to be weighed by a S+f er to get truth.
    Why the V6 is not 225hp out of the box makes no sense IMO.
  3. #18
    Dec 2019
    Spring Lake MI
    Wonder how it stacks up to a 150 Yamaha with the Nizpro tuned 231hp. Although the lower would need to be modded on the Yamaha.
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
  4. #19
    Dec 2009
    middle tennessee
    Quote Originally Posted by hellbents-10 View Post
    The yamaha would need better mounts too unless I am mistaken... I wonder if anyone has them yet... Id love to try a tuned 150 SHO with solid mounts and my 3.0 merc sporty mounted on it on the Allison.
  5. #20
    Dec 2019
    Spring Lake MI
    Tuff has done a couple 20s with the flashed 150 and ran 80+mph with the stock lowers.
    Tuff 24 300xs
    Tuff 16 90 Yammie
  6. Likes John S liked this post
  7. #21
    Jun 2018
    Floating around
    I wonder whats the deal with the sporty being so much heavier? Is the bullet gigantic diameter or something? Gotta wonder about the handling on our small hulls?
  8. #22
    Feb 2003
    Rochester, NY
    I can tell you from personal experience that the Sportmaster gearcase - even though it will probably prove to be almost indestructible on smaller boats - leads to some interesting handling quirks. I have one on my Progression 22 on a 250R mounted on a manually adjustable 10" Bob's Machine jack plate.
    Although the SM is probably great on multi engine boats, a single engine application presents some issues. First, although the SM gearcase is durable, it's huge. Fortunately, it has low water pickups mounted in the lower portion of the gearcase so you can run it surfaced. This is great if you have a powered jack plate. If you don't - like me - you crank it up as far as you can and still get out of the hole and maintain decent water pressure. But in my application, there's still too much gearcase in the water and it literally tries to lift and steer the stern around. I'm pretty sure that if I had the straight skeg (instead of the cambered one) and a power jack plate, I could get it up high enough to at least lessen the effects.
    The other issue is that Mother Mercury doesn't see fit to offer wing plate hydraulic steering mounts on anything less than a 300R. This leads to one having to trust one of the many front / tiller mount systems. (I have the Seastar Pro system.) Coming from a full Latham wing plate system on my previous Mercury 2.5 / 200, I can tell you that my confidence level in running hard with this system just isn't near as great. And then there's that one "Jesus Bolt" that everything depends on ...
    Finally, I don't know about the new smaller R motors, but mine only has solid lower mounts from the factory. Although they claim that the upper mounts are special and not as mushy as the fishing motors, you should see the movement back there at speed and in rough water. Add all of this together and you'll understand why I'm still struggling with my setup.
    1992 Progression 22
    Mercury Racing 250R
  9. Thanks LakeFever thanked for this post
    Likes LakeFever, Greg G, JBS liked this post
  10. #23
    Jul 2008
    Denton, Md.
    HydroTec makes the solid mounts for the 150 and 175 SHO.
    We only go through this circus once...so enjoy the rides!!!
  11. #24
    Dec 2009
    middle tennessee
    Interesting..I just messaged them today and they said that they do not
  12. #25
    Lake Coochiching, Ontario
    Somehow I just expected the 200R to have a version of the old 4.75” sportmaster. The old size would be plenty strong enough for a 200
  13. Likes aj06bolt12r, 22R liked this post
  14. #26
    Jul 2004
    Connecticut
    Is it confirmed it is the 5 1/4?
  15. #27
    Dec 2009
    middle tennessee
    I don't know for sure.. But the answer to that question will tell us whether this package was put together by the enthusiasts in the Merc Racing division or by bean counters in marketing.
  16. Likes Greg G, 22R, LakeFever, JBS liked this post
  17. #28
    curious why they don't offer 20" mid, counter rotation on the 200R .. this just feels like a 200Pro XS with a sportmaster gearcase
  18. #29
    Jul 2004
    Connecticut
    Doesn't it also have solid mounts and a higher RPM?
  19. Likes noli, LakeFever liked this post
  20. #30
    SOCAL, the land of 75* and sunny!
    I feel like this announcement/ thread started out for some of you as the hottest broad in the bar coming up to talk to you, and has now turned into the realization that when she leaned in to kiss you, that isn't a conceal carry revolver tucked in the front of her tight jeans.
  21. Thanks noli thanked for this post
    Likes sonicss33, noli, AlliStan liked this post
  1. Photos: Mercury Racing 200R or 225R??
    Last Post: 11-28-2023, 06:44 PM
  2. Mercury Announces New X-Site Test Facility
    By Scream And Fly in forum Outboard and Racing History
    Last Post: 05-03-2004, 09:13 AM
  3. Mercury Announces New X-Site Test Facility
    Last Post: 03-20-2004, 01:13 AM
  4. Mercury Announces New X-Site Test Facility
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 03-19-2004, 01:31 PM
