Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
  1. #31
    Sep 2021
    Conway SC
    Quote Originally Posted by John S View Post
    I feel like this announcement/ thread started out for some of you as the hottest broad in the bar coming up to talk to you, and has now turned into the realization that when she leaned in to kiss you, that isn't a conceal carry revolver tucked in the front of her tight jeans.
    That's funny...and disturbing at the same time!
  2. Likes noli liked this post
  3. #32
    Aug 2013
    Oshkosh, WI
    Quote Originally Posted by aj06bolt12r View Post
    I don't know for sure.. But the answer to that question will tell us whether this package was put together by the enthusiasts in the Merc Racing division or by bean counters in marketing.
    Four stroke Sport Master conversion about 4 years ago, it ran faster and handled better than the 3L Sporty after a prop change. It also had zero water intrusion after some good time spent over 100 mph, which is something I could never say about the 3L Sporty
    2000 Triad Mod VP 280 ROS
  4. Likes Speed Jr. liked this post
  5. #33
    Dec 2009
    middle tennessee
    Quote Originally Posted by Petey View Post
    Your running the V8 sportmaster on that Opti? And you like it better? Interesting.. Did you have to raise the engine to get the same performance? What prop were you running and what did you switch to? What made the prop change necessary? Needed a bigger diameter wheel?
  6. #34
    Dec 2009
    middle tennessee
    Also what did you have to modify to make it fit?
  7. #35
    We have been running a 3.4 with a sportmaster on it for 3 trouble free years. Yes it has a hydraulic plate, yes we added solid mounts, yes we run the motor high, yes its fast and sips fuel.
    JoeClick image for larger version.
  8. #36
    Dec 2009
    middle tennessee
    Joe! I am glad you have chosen to weigh in on this discussion! I say this because I know that you know high performance recreational boating as well as anyone on this forum. I also know that you posess the means to run whatever you feel like running... For sure in the sub 24ft performance boat market at the very least... So the fact that you have chosen the 3.4 platform carries a lot of weight to me.
    But I have so many questions.. The picture shows a 200r... But that has not been out for 3 years.. Did you get one early somehow? If not I assume that you mean that you have been running maybe a 3.4 225 with solid mounts and a sporty added for 3 trouble free years? Are you running the v8 sporty case or a modified 3.0 case?
    I know you and your family know 20ft Allisons.... How do you feel that this 3.4 200r would push an XB2003 compared to 3.0/3.2 Merc or 3.4 Etec power?
    Thanks!
  9. Likes hellbents-10 liked this post
  10. #37
    Aug 2013
    Oshkosh, WI
    Back when I had this boat yes. It was a stud change and drive shaft swap. That was an L6 400R gear case, not a V6/V8, but same size housing. The L6's still had a conventional shift shaft so it was still full shifting but opposite throw for forward and reverse. All of the newer V6/V8/V10s have the electronic shift actuator bolted directly to the gear case. I ran a worked 30 Eagle 4 for top end with the 3L case to 98-99 mph and I think I was 1 3/8" above. Raised it to 2" above with the 5.44" Sporty and ran a MAX5 ST and 5 blade cleaver to 102-103.
  11. Thanks aj06bolt12r thanked for this post
    Likes HydroSkreamin, hellbents-10 liked this post
  1. Photos: Mercury Racing 200R or 225R??
    Last Post: 11-28-2023, 06:44 PM
  2. Mercury Announces New X-Site Test Facility
    By Scream And Fly in forum Outboard and Racing History
    Last Post: 05-03-2004, 09:13 AM
  3. Mercury Announces New X-Site Test Facility
    Last Post: 03-20-2004, 01:13 AM
  4. Mercury Announces New X-Site Test Facility
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 03-19-2004, 01:31 PM
