Results 1 to 4 of 4
    Nov 2004
    South Haven, MN
    1986 V-King 1988 Merc 200 questions...
    I set up a 1986 Hydrostream V-King with a 1988 Merc 200 carb with the oil injection removed, today, with a 26" pitch inline chopper I hit 79mph on my gps. I know I'm turning between 6,000-6,500rpms, is using Amsoil mixed at 50:1 good enough? At what speed does a stock Mercury gearcase blowout? And finally this Merc seems to have a "rough" idle, it doesn't die out or anything like that but what can I check to try to smooth it out? Thanks!
    TX......somewhere?
    they will idle like an 'ole dirt track motor... if tha can has been removed then its jus a bit louder....
    think 85 +/- a couple is general consensus........
    Aug 2021
    Osteen/Deltona, FL
    Running a fishing motor in the 6,000+ rpm range, I like 40:1 mix, but that's just my opinion.
    A good set of reeds can help with idle, but it also depends on what your idle rpm is set at while in the water. Maybe try and bump it up a couple hundred.
    83 Vking 150 Mariner 2.5L
    Nov 2004
    South Haven, MN
    What set of reeds would you recommend? Are Boyesen Power reeds #265r good?
  1. 1986 Hydrostream V-king, Pad-V
    By Iceout in forum Hulls up to 20'
    Last Post: 07-18-2014, 08:14 AM
  2. 1986 Merc 225 HELP QUESTIONS
    By hemifred in forum Technical Discussion
    Last Post: 06-05-2013, 02:34 PM
  3. Mercury Tech: 1988 8 hp merc questions
    By JoshKeller in forum Technical Discussion
    Last Post: 06-18-2010, 03:58 PM
  4. setup for 80 v-king - 86 150 merc v6 questions
    By streaming demon in forum Props, Setup, and Rigging
    Last Post: 01-10-2005, 02:40 PM
  5. 1986 hydrostream V-King
    By air_jigger in forum General Boating Discussion
    Last Post: 01-27-2004, 06:49 PM
