Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 69
    Jun 2018
    Floating around
    2.0L 135 fatblock heads on 2.5L 200?
    Heard good things about this mod. Anyone try it? I havent pulled the heads off my 135 yet to CC them but I am curious to hear your thoughts
    Jan 2020
    Pinole, Ca
    Make about 160 psi of compression with the smaller pocket.
  3. Thanks LakeFever thanked for this post
    Jun 2018
    Floating around
    Sounds killer but it also sounds too high for pump gas, even with aces that much squeeze makes me nervous to try
    Jan 2020
    Pinole, Ca
    Yeah I would run 93 minimum with that compression.
    Jun 2009
    Bristol, Connecticut
    Are you serious
    Jun 2009
    Youre talking about the heads with the 6 lines around the plug holes and dowel pins at the ends?
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by Aaronhl View Post
    No. The 6 lines mean nothing. We are talking about 2.0L heads on a 2.5L from both motors of the same era.
  9. #8
    Apr 2023
    Long island, NY
    From what I have heard, putting 2.0 heads on a 2.5 will give you about 160psi. Questionable for pump gas. But putting 2.4 heads on a 2.5 will give you around 140psi. Good for pump gas, just not regular.
  10. #9
    Nov 2021
    N. Idaho
    Late model 2L heads added 10lbs to my 2.5 engine, for a total of 120lbs. Kind of a disappointment. Still less than my factory 150 supermag that has 130lbs.
    Idk if I have a bunch of junk or what, but the three 2.5/200's I own (with stock heads) have 110lbs of compression. With 5% or less leak down.
    On a side note. I run 190lbs of compression in a chainsaw, and use pump gas.
  11. Thanks David - WI thanked for this post
    Jun 2018
    Floating around
    I think I’d be trying another compression tester there onpad
    Nov 2021
    N. Idaho
    I think it's pretty accurate.
  14. #12
    Apr 2023
    Long island, NY
    Service manual calls for 110-135psi. No more than 15psi variance. Most of my motors have 115-120psi
  15. Likes OnPad liked this post
  16. #13
    Nov 2021
    N. Idaho
    Not exactly apples to apples, but heres a couple people that swapped 2L heads to a 2.4, and had similar results.
    https://www.screamandfly.com/showthr...ssion-question
    I used 1996 2l heads #18787c4 on a mid nineties 2.5. That had 18488c4 heads.
  17. #14
    Lots of things affect cranking compression numbers... in northern Idaho, probably elevation? Add maybe 4% for every 1,000' above sea level... roughly?
    Trump!
  18. Thanks OnPad thanked for this post
  19. #15
    Nov 2021
    N. Idaho
    Yep, 2200ft probably puts me about 8-10 lbs down.
    No bs about the 2 litre heads.....+10lbs is all I gained.
    Used 18787 heads are kinda expensive. A good pair brings about what Skialot paid for his last engine .
  20. Likes LakeFever liked this post
  1. 2.4 Fatblock which heads to cut? 2.4 or 2.5?
    By coffeeguy in forum Technical Discussion
    Last Post: 12-30-2014, 11:31 PM
  2. 1991 2.4 Fatblock Cutting Heads and other cheap hp gains
    Last Post: 12-27-2014, 01:54 PM
  3. Bridgeport, fatblock? what does this mean?
    By tfrizz80 in forum Technical Discussion
    Last Post: 09-27-2012, 04:13 PM
  4. Fatblock
    By Jerry Millington in forum Technical Discussion
    Last Post: 06-20-2006, 11:06 AM
