Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 69 of 69
  1. #61
    Jul 2008
    severn bridge
    I recall being told a 40 years ago you can't compression test an omc accurately because the rings need crankcase backpressure on the rings to seal them. you can compare cylinders but the gauge won't give you true operating pressures
    true or false?
  2. #62
    Jun 2018
    Floating around
    No clue but I’ve heard many things over the years about compression tests being iffy. Dump a little oil in the cylinders first to sell a crap motor was one etc. From my perspective it’s a simple fast way to verify consistency across all holes regardless of the number and in my last test even though the gauge is fragged it did at least show there was a gain and it wasn’t huge and that was enough for me. New cheapo tester arrived today so take this for what you will this is the small chamber heads today
  3. #63
    TX......somewhere?
    thats pretty consistent with what we usually came up with......... we had pretty accurate gauges... same ones we used on top fuel/alcohol Brad motors.. which wasn't very often..... internal problems with those was usually pretty obvious .....
  4. #64
    Jun 2018
    Floating around
    I'm going to run a controlled test on that tester when I get time to home brew certify it.
  5. #65
    Nov 2020
    New Zealand
    Those omc rings are tapered and I'd say that could be a point.
    Simple to put the gauge in, earth the plug and run the motor.
    Mercs that have 120psi at cranking speed have 135 at idle, from memory.
    Oil build up is a big factor.
    I've seen 170psi in a 150psi motor from oil built up in the running cylinder
  6. #66
    Apr 2023
    Long island, NY
    Compression gauges never seem to be accurate. They always seem to read a little low. especially the cheap ones. Probably why all manufactures seem to say equal pressure is more important than the actual pressure.
  7. Likes LakeFever liked this post
  8. #67
    Nov 2020
    New Zealand
    I just plug them into a couple of different compressors that have gauges and regulators on them.
    If they all match up I'm happier that the compression tester is probably close.
  9. Likes LakeFever, skialot2 liked this post
  10. #68
    Jun 2018
    Floating around
    Quote Originally Posted by NZ Sidewinder View Post
    Thats what Im going to do when I have some spare time. Burning up all the time I have running the boat so very little tinker time right now
  11. #69
    Nov 2020
    New Zealand
    Time is the enemy
  12. Likes LakeFever liked this post
  1. 2.4 Fatblock which heads to cut? 2.4 or 2.5?
    By coffeeguy in forum Technical Discussion
    Last Post: 12-30-2014, 11:31 PM
  2. 1991 2.4 Fatblock Cutting Heads and other cheap hp gains
    Last Post: 12-27-2014, 01:54 PM
  3. Bridgeport, fatblock? what does this mean?
    By tfrizz80 in forum Technical Discussion
    Last Post: 09-27-2012, 04:13 PM
  4. Fatblock
    By Jerry Millington in forum Technical Discussion
    Last Post: 06-20-2006, 11:06 AM
