Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Jun 2014
    South Carolina
    But they are remarkably quiet​ (and tough) compared to the lightweight "racing" cowls.
    No doubt they are solid and I actually like the look of em! I might try and pop a lightweight version down the road, focusing on the hatch for now it's easier and heavier.
    I'll report back with some findings on layup when I get back to it. Thanks guys
  2. #17
    Nov 2020
    New Zealand
    One question I have is whether to use uni or plain for infusing Carbon.
    Uni is more difficult to pull epoxy through.
    Instead of 2 layers of uni, why not 3 layers of plain.
    For me it's a question of risk versus weight.
    3 plain layers will have less risk of dry spots but be a little heavier.
    I'm just starting out on this journey
  3. #18
    Jun 2018
    Floating around
    If you haven’t made your test pieces yet you can always make a small piece with careful measurements to get a weight per square inch number. Something like a 4” x 4” by 1/2” coosa with a single layer of 1708 on it. Weigh it before the lay and after. Then add a second lay of 1708 over it and weigh it again etc. then using the weight values apply the math to your hatch and cowl sizing and calculate out your projected weight. For what it’s work it takes 0.65ml of resin for every square inch of 1708. You can use that as well for some rough weight calculations.
    Can’t help with the carbon fibre. I’ve never touched the stuff. I did find discussions that cf is not as strong as fiberglass though. It was a fairly compelling explanation.
  4. Likes NICE PAIR liked this post
  5. #19
    Aug 2021
    Osteen/Deltona, FL
    When I watch a racing cowl bounce around and shake itself apart, it makes me love my heavy fishing cowl lol
    83 Vking 150 Mariner 2.5L
  6. Likes David - WI, NICE PAIR liked this post
  7. #20
    Jun 2018
    Floating around
    Quote Originally Posted by VkingMike View Post
    mine shakes around like crazy. It’s my first one and it is surprising. Considering some reinforcements
  8. Likes NICE PAIR liked this post
  9. #21
    Nov 2020
    New Zealand
    This is my current project.
    It's a male mold for an infused UIM standard racing safety cell.
    20mm devini foam core, glass/ carbon/ kevlar
    Screen frame is multi core/ carbon/ kevlar laminate.
    Aiming for 4000N UIM test sample.
    Its for a vee mono.
    Mold is coated in Durapox and ready to sand.Click image for larger version.
    Screen is to be 6mm polycarbonate and the frame is fabricated in multi core g/ k/ C laminate.
  10. Likes LakeFever, NICE PAIR, NeedOne liked this post
  11. #22
    Quote Originally Posted by NZ Sidewinder View Post
    Its for a vee mono.
    Nice!
  1. Layup recommendations????
    By Dougw in forum Fiberglass and Composites Discussion
    Last Post: 01-08-2011, 12:00 AM
  2. Lightweight Crossflow Pistons, latest design
    By B.Leonard in forum Technical Discussion
    Last Post: 05-21-2004, 08:09 AM
  3. I sure like the look~1988 STV Lightweight Hull Design
    By thaw ripper in forum General Boating Discussion
    Last Post: 01-25-2004, 06:47 PM
  4. fiberglass layup
    By patchesII in forum Fiberglass and Composites Discussion
    Last Post: 11-19-2002, 04:53 PM
