Results 1 to 3 of 3
    Sep 2006
    Carbon Kevlar T750 Hull
    Folk need some advise
    Planning to build a light weight T750 hull out of Carbon Kelvar to compensate for my weight.
    Would like to hear from the experts your thoughts on the following:
    • The suggested cloth layup for the hull
    • The recommended hull thickness
    • Pros and cons
    • An other concerns or suggestions
    Thanks
    Not sure what the name of the material is but racing kayaks are built using an interwoven carbon/kevlar and one layer is quite strong. I would think two layers with a thin core, vaccum bagged with some stringers of the same material all vaccum bagged would be very rigid and light. For the transom I would use a honeycomb sandwich panel... or multiple panels laminated together. Flat pressure bulkhead panels in airplanes are light but enormously strong. They are carbon honeycomb panels.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
    Nov 2020
    New Zealand
    I'm in the same learning process.
    For my particular project it's vacuum infusing but I've often wondered how I'd make a composite core hull.
    Initially I thought that probably best to build a foam sheet hull over frames and epoxy glass that.
    Then turn it over and do the inside.
    That's a totally wet manual lay up
    But now that I'm studying infusion methods, I'd probably go that way.
    From building / repairing other hulls I leaned that strakes should be attached afterwards.
    That is, build the hull, then glue and screw the strakes on.
    I have a system of doing this where the edges of the strakes can easily be made razor sharp without using filler.
    I don't use polyester for anything structural, all epoxy and also Vynle, however it's spelt.
    For years I only used a brush to work the composite but now I use a brush and a roller.
    Rollers really get the resins moving.
  1. 19' DCB Carbon/Kevlar light weight
    By The War Canoe in forum Hulls up to 20'
    Last Post: 07-15-2014, 07:00 PM
  2. Carbon/Kevlar Hybrid
    By Ryan mcc in forum Fiberglass and Composites Discussion
    Last Post: 05-17-2008, 08:32 PM
  3. Carbon & Kevlar - Where to buy?
    By Stoker1 in forum Fiberglass and Composites Discussion
    Last Post: 09-18-2007, 09:21 AM
