Results 1 to 5 of 5
03-27-2024, 08:24 AM #1
Screws into coosa. 5200? Marine Tex? Nothing?
I did a bit of testing with screws into coosa and found so long as you pre drill a pilot they seem to go in and hold quite well. That’s fine and dandy for a bench test but considering the pounding the water does to shake everything up and that I have read screws into coosa isn’t so good I figured I’d ask if any of you have tips or suggestions on how to make this work best as possible. Thanks gents
03-29-2024, 07:59 PM #25000 RPM
- Feb 2002
- The great corn desert of Iowa
- 317
- 28
- 47
- 219
I always thought you could screw into Coosa, especially with some glass backing. Their website lists screw retention numbers. https://coosacomposites.com/wp-conte...al-1.26.24.pdf
1971 Sidewinder 14 SS w Johnson 90 v-4
1959 Texas Maid Falcon w Mercury Mark 35A
1981 Sylvan Sportster w Johnson 85 v-4
2006 Harris pontoon with a Yamaha 90
1969 Sunfish sailboat
03-30-2024, 06:52 AM #3
I’ve done some bench testing and yes coosa seems to hold a screw just fine. It definitely prefers a pilot hole though. I usually use some epoxy when screwing into glass or wood to seal and maintain the hole integrity over time. I’ve had many snaps and roof bracket screws on other boats come loose and need attention over the years which were factory built with no epoxy etc so I’m looking long haul here with the coosa. I’ve also seen some comments here and there about screwing into coosa is not as durable long term as wood which is why I posted. Guess I’m going to have to do some more tests and report back lol
04-06-2024, 04:27 PM #4Team Member
- Jun 2004
- long island
- 3,068
- 1101
- 875
- 4999
- 9145
Maybe check the Geogon Brothers website
makers of West System Epoxy
It is pretty informative and diverse for information
Overdrilling the hole and filling with epoxy comes to mind
Good Luck!
LakeFever, XstreamVking liked this post
11-11-2024, 08:04 AM #5
Wanted to update this for anyone wondering the same. I used 1/2 20lb coosa bluewater for my floor capped it with one lay of 1708 and the underside with one lay of 1.5oz csm using promoted vinylester resin. I mounted an aluminum 28 gallon tank using stainless 5/16” threaded lags. I pilot drilled the coosa first and using a small brush I coated the holes with vinylester resin and dipped the lags into the resin as well before screwing down.
I ran the boat hard in some very extreme conditions a couple times the whole rig took a pounding. 54 hours of use and these screwed lags are as tight as the day I put them in. Hope this helps someoneHydrostream dreamin
sonicss33 thanked for this post
Two layers of 3/4 Coosa vs a single layer of 1.5" Coosa
By ADDvanced in forum Fiberglass and Composites DiscussionReplies: 17Last Post: 06-10-2021, 01:36 PM -
3m 5200 marine sealant
By 2old2moto in forum General Boating DiscussionReplies: 23Last Post: 05-18-2013, 02:24 PM
