Results 1 to 12 of 12
Thread: Mercury 2.5 Questions
03-23-2024, 04:09 PM #15000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Can you run surface gap spark plugs with the CDM ignition or do you have to use switch boxes?
Does the efi (tbi) fuel system need to run with the CDM ignition or can it run with the switchboxes?
03-23-2024, 04:13 PM #2
efi can run on switchboxes. Surface gap can run with cdm but they have to be resistor type like the BUZHW
Glastron1987 thanked for this postGlastron1987 liked this post
03-24-2024, 06:31 AM #35000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Great. Among all my boats, I have a 135-2L, 150-2L, 150-XR4, and a 175-Ski, and have just started building a 200-2.5L. So good to know what my options are for the 200.
BUZHW appears to be regular gap, so I think it would be the BUZ8H that you are referring to being surface gap resistor?
03-24-2024, 09:54 PM #4
BUZHW should be a surface gap..............
03-25-2024, 01:44 AM #5
Surface gaps are really for "fishing motors"... they can foul and foul and still find a place to fire; but they really aren't the hi-perf choice.
They fire, but there isn't much fuel/air in the gap when they do.
03-25-2024, 06:32 PM #65000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
25two.stroke liked this post
03-27-2024, 02:49 PM #7
ok u decided on the 200 2.5 which one are u picking up
03-27-2024, 03:13 PM #8
Search Products | West Marine
they may be a discontinued plug????Last edited by tlwjkw; 03-27-2024 at 03:15 PM.
03-27-2024, 03:38 PM #9
03-28-2024, 06:42 PM #105000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
03-28-2024, 06:43 PM #115000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
03-28-2024, 06:53 PM #125000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Oh let me explain...
I like a carbed motor without oil injection because its so simple and reliable.
But I like oil injection because then I don't need to worry about mixing the gas, and truthfully I don't run enough rpms to worry about that plastic oil gear.
The XRI is cool because is seem easier than all those little carb parts, but I don't like the extra few lbs.
So, the TBI EFI looks great with how it should run, but again another few lbs., and I believe you have to run oil injection.
Also, I like those surface gap plugs because they last forever and never need much attention.
Slow decision.
Mercury Tech: Mercury 2.5 questions
By DieselDood in forum Technical DiscussionReplies: 11Last Post: 01-11-2021, 10:31 AM -
Mercury cle questions
By Charger20sv in forum Technical DiscussionReplies: 3Last Post: 10-17-2018, 08:00 PM -
40 hp 4 cyl mercury questions?
By 87vantage in forum Technical DiscussionReplies: 4Last Post: 10-25-2012, 11:11 AM -
Mercury fi questions
By skiboater in forum Technical DiscussionReplies: 0Last Post: 09-06-2010, 04:09 PM -
Mercury Tech: Mercury 200 Questions
By Greg in forum Technical DiscussionReplies: 7Last Post: 12-15-2008, 10:40 PM
