Results 1 to 11 of 11
Thread: 2.5 280 Break in??
03-21-2024, 04:15 PM #1
2.5 280 Break in??
I just freshened up my 280. I reused my mercury pistons as they had no scuff's or wear. Diamond honed, new mercury rings and bearings.
What type of oil should I use and at what ratio for break in? I have heard that the Mercury racing oil was to slippery to use for break in. Not sure?
How many hours and what kind of RPM should l run at for the best results?
Thanks in advance!!
Stoney
03-23-2024, 11:16 PM #2
I've had decent success running Dino oil 32/1 for 6 hours before I started to lean on it.
David - WI liked this post
03-24-2024, 08:18 AM #3
I am going with the Quicksilver non synthetic for a period of time.
Michael J Giesler liked this post
04-03-2024, 09:01 AM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
04-03-2024, 10:07 AM #5
04-05-2024, 03:52 PM #6Member
- Jul 2015
- paloaltl ca.
- 33
reset the ecu to break in mode
luv2gofast liked this post
04-06-2024, 09:54 AM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
IMO if it has one new steel sleeve needs break in as a steel engine. That can also change with clearance and what piston is in it. I can tell you the ported S3000 Greg and I use to run at the enduro were run on the ramp for 1 hour with slight increase in rpm every 15 minutes after a full heat cycle. I would also control water flow during this to raise and lower block temps. We then ran them another 30 minutes on the water at 5000 or less then 15 minutes with short bursts to WOT. Prop tests and would generally start the race with 2.5 hours total time on new Wizard pistons and rings.
Baker343 thanked for this post
04-09-2024, 09:27 AM #8Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
In my opinion the load on the engine is most important. I’d put a big wheel on it and back it in deep on the trailer and spend a couple 10 minute sessions there. Watch the temps close and keep the rpm between 2000 and 4000
Erik Kiser
04-09-2024, 02:23 PM #9
bobby use cringe n make all kinda weird faces when i'd start hammerin' ona new one after 'bout 15 ta 20 minutes.............
04-09-2024, 03:18 PM #10
Never broke in any of my 2.5 Nic motors (260/280/300) with only doing rings and bearings. Just ran a few miles to come to temp and then let it eat. Always ran Klotz oil and never had a issue with rings seating.
04-16-2024, 08:50 PM #11
What I ultimately wound up doing for my 280 break in of new rings and bearings was I used a 32 pitch 4 blade prop and put the motor under a load and varied the rpm. I also used double Blue dino oil.
1'st hour under 3500 rpm's varying the rpm's
2nd hour under 4500 rpm varying the rpm's
3rd hour under 5000 rpm varying the rpm's
Second tank of gas I ran my red Mercury racing oil at 5 oz per gallon.
Keeping the rpm's under 6000 rpm.
That may be over kill but I feel good about the process.
Thanks Stoney
Mercury Tech: break in
By bigbluechevy454 in forum Technical DiscussionReplies: 10Last Post: 04-04-2012, 12:34 PM -
Mercury Tech: 2.5 200 EFI Break in?
By mxz in forum Technical DiscussionReplies: 5Last Post: 10-09-2010, 12:09 PM -
32.5x14 cleaver prop blades break off 24' twin Skater. What brands don't break?
By velvetl in forum Technical DiscussionReplies: 4Last Post: 07-25-2008, 08:14 PM -
Break in for EFI
By bep078 in forum Technical DiscussionReplies: 0Last Post: 02-26-2007, 03:34 PM -
2.5's Break In
By Bam Bam in forum Technical DiscussionReplies: 3Last Post: 06-23-2003, 10:13 AM
