Results 1 to 6 of 6
    Feb 2024
    US
    laptop switching off as soon as it connect to projector
    Hi all
    my laptop is switching off as it connects to projector, what could be the issue.? it works fine for entire day but failed when trying to connect it with projector.
    Aug 2021
    Osteen/Deltona, FL
    Is it actually turning off or is the screen going blank?
    83 Vking 150 Mariner 2.5L
    Look for settings for eARC or CEC that have to do with your HDMI connection... basically one HDMI device can turn on/off of "sleep"the other device. You might just try a normal non-ARC HDMI cable if you can't figure out the settings?
    Feb 2024
    USA, New York
    It's possible that the power settings are causing an issue. Try adjusting the power plan to prevent the laptop from shutting down when connected to the projector.
    Feb 2024
    US
    its not going black or void, it just turned off or sometimes if it doesn't turn off, projector isn't connected.
    Feb 2024
    USA, New York
    You should first plug in the cable to the port on both your laptop and the projector after identifying the cable (HDMI, DVI, or VGA).
  1. Best way to connect top/bottom
    By play2win in forum Fiberglass and Composites Discussion
    Last Post: 02-28-2010, 02:28 AM
  2. Projector Headlights
    By msc5195 in forum The Scream And Fly Lounge
    Last Post: 03-18-2006, 09:32 PM
  3. USB Connect
    By hevysrf in forum Media Creation - Photo and Video Discussion
    Last Post: 11-05-2004, 11:51 PM
