Results 1 to 7 of 7
02-11-2024, 03:07 PM #1
Looking for back half block for 260, 280, or 300
****UPDATE, FOUND ONE*****
Small bearing block could be nikasil, steel sleeved, or some combination. If it needs sleeves that's okay also. Let me know what you have. Thanks. BobLast edited by Laser88; 03-04-2024 at 11:54 AM.
1989 Allison XR2002 200 Promax (Thank you Nelson!)
2014 King of the Hill 85 V-King 200 Promax (they let me win) Sold
88 yellar laser 175 black max (Thank you Robby!) Sold
79 Viper 115 Johnnyrude (sold)
02-14-2024, 11:56 PM #2
Are you wanting one to measure ports off of or one to build? I have some screwed up 260s and a screwed up 280. All need welding, not just sleeve work. What exactly are you after?
02-15-2024, 07:59 AM #3
02-15-2024, 08:59 AM #4
I would give Rob a call at Marine Machine. He may be able to fix that.
1973 Viper - sold
1978 Viking - sold
1995 XB02
02-15-2024, 01:42 PM #5
Thank you for your suggestion. Since you offered a potential remedy, I am operating under the assumption that you have a deep knowledge of metallurgy and welding.
Here's what I see: The crack starts from #5 cylinder from the poppet on the outside of the block all the way through the water jacket, exhaust port, and through the bottom of the sleeve holder. You can spray WD-40 on the outside of the block and it will end up inside the cylinder. This crack is behind the water jacket and I wonder if he could contort himself to position the welding tip in such a tight space? Really it's difficult even to see it behind the sleeve holder. Otherwise the sleeve holder might need to be completely removed and then I don't know where we would go from there?
After reading my reply, do you still think it would be worth troubling Rob? If yes, would you please send his contact info my way?
Many thanks in advance. Cheers
02-15-2024, 02:08 PM #6
03-04-2024, 11:49 AM #7
Found one. Thanks Scream&Fly
Wanting bridgeport 2. 4 block back half
By chrisso in forum Misc. Parts and AccessoriesReplies: 1Last Post: 07-21-2016, 09:27 PM
