Results 1 to 12 of 12
02-03-2024, 08:54 PM #1
Water pressure in a sportmaster at 60MPH
What type of water pressure normally happens in a lower unit before it hits the water pump?
Thanks, Carter Powell
02-04-2024, 07:02 PM #26000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,611
- 474
- 75
- 449
- 500
fresh water or salt?
02-04-2024, 08:47 PM #3
Fresh! Just trying to get an idea of the water pressure before it gets to the water pump.
thanks, Carter
02-09-2024, 06:38 PM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,611
- 474
- 75
- 449
- 500
im thinking no more than 30 lbs?
02-10-2024, 07:23 PM #55000 RPM
- Jun 2014
- United States
- 156
- 7
- 30
- 42
How and where are you gauging water pressure before the water pump?
02-10-2024, 09:16 PM #6
probably depends on whether ya hooked up to a garden hose or fire hydrant... sittin' still or runnin a hundred... never heard of anyone tryin' ta read "before" pump pressure..
02-11-2024, 02:08 AM #7
Probably not a lot. Otherwise, you would not overheat when going fast with a bad impeller. But you do.
02-11-2024, 01:07 PM #8
Water psi is calculated as velocity squared times .0142
So, 60X60X.0142=51.12 psi
RT2023 TUFF 25
OnPad, David - WI liked this post
02-11-2024, 03:38 PM #9
So I guess my original question should have been, how does this type of pressure effect the water pump impeller as the pressure rises? This is just something that I never thought about.
Many thanks, Carter
02-11-2024, 04:27 PM #10
It was an interesting question. Pitot pressure suggests there is for 70lbs at 70 mph and 144lbs at 100mph. That is not a flow thru situation. Cooling requires an abundant flow and relatively low pressure. High pressure in cooling suggests flow is hindered.
Jim
02-13-2024, 07:12 PM #11
the water pressure pre-impeller is irrelevent, it is basically a centrifical pump and works totally on suction
02-14-2024, 10:56 AM #12
Water pressure at 80mph and up is often higher with some gearcases. Over 100 mph over pressure can be an issue. AT those speeds the water pump is absolutely under pressure.
Jim
Mercury Tech: 2005 Mercury 2.5 XS with Sportmaster Lower Unit - Water Pressure ???
By wrbaum in forum Technical DiscussionReplies: 1Last Post: 06-16-2023, 11:57 AM -
How to increase water pressure 3.0 sportmaster
By darkdream in forum Props, Setup, and RiggingReplies: 14Last Post: 06-27-2019, 06:10 AM -
Sportmaster High water pressure / Flow
By inspectorlance in forum Technical DiscussionReplies: 10Last Post: 07-13-2009, 10:00 AM -
No water pressure on Sportmaster
By RedVegas91 in forum Technical DiscussionReplies: 1Last Post: 06-05-2005, 11:20 PM
