View Poll Results: Should you ever use clear coat on a boat?
- Voters
- 5. You may not vote on this poll
Never clear coat a boat!
3 60.00% -
Clear coat is awesome for a boat!
2 40.00%
Results 1 to 6 of 6
Thread: Clear coat on a boat
01-05-2024, 08:14 PM #15000 RPM
- Jan 2013
- N/A
- 164
- 7
- 7
- 13
- 48
In the middle of my 50th razor blade removing old clear coat...
NICE PAIR liked this post
01-07-2024, 04:51 PM #2Team Member
- Lake Coochiching, Ontario
- 7,774
- 24
- 276
- 490
- 1596
- 6 Post(s)
Would clear coat be a bad idea over a painted hull? Was your hull clear coated over gel?
01-07-2024, 06:11 PM #36000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,238
- 55
- 300
- 2757
- 3879
01-07-2024, 10:51 PM #4
I would say auto type clear coat over chalked gel as a “resto” is not going to last very well. Clear gel over faded gel is a win. Auto type clear coat over properly prepped and painted deck is good to go. Auto paint on the hull below the water line is not going to be good at all.
CUDA liked this post
01-08-2024, 06:42 PM #5
01-09-2024, 11:56 AM #65000 RPM
- Jan 2013
- N/A
- 164
- 7
- 7
- 13
- 48
From what I can guess; the red is painted very very well, however there was a layer of clear that started to peel on the stripes. The clear didn't extend to the paint so a razor really worked perfect at removing it right up to the red paint line. I'm not sure about clearing the stripes gel in this situation; I was able to wet wet sand up to 5k and it came out beautiful. (2 pictures below before; 1 after)
I'm working on the black windscreen which is removable and want to prime to paint white, removing the existing clear on it. I did think about using aircraft remover but it didn't appear to be fiberglass safe and didn't realize there is fiberglass safe paint remover. Thank you for those details; I ordered the removal and going to bring the windscreen into my heated garage and give it a try in +60f.
Thanks to all for the great feedback on the topic; there's not much information out there, hope this helps others.
Boat Wax for clear coat
By BKlingel418 in forum General Boating DiscussionReplies: 11Last Post: 01-13-2019, 10:42 PM -
base coat clear coat WITH PEARL chameleon added
By roadkill636 in forum Appearance ModsReplies: 7Last Post: 12-23-2015, 04:41 PM -
Clear coat advice needed on alumanum boat
By roadkill636 in forum Technical DiscussionReplies: 1Last Post: 04-23-2009, 01:18 PM -
clear coat OR not to clear coat that is the question.
By nitewolf in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 09-03-2002, 03:03 PM
