Results 1 to 2 of 2
    May 2023
    Advice on fixing my transom and if I should remove top cap
    Title pretty much says it all. I bought a 1988 ski boat and when I took off the rub rails and aluminum trnasom plate I noticed alot of craking at the transom and the wood probably has been exposed. I want to so it right and I noticed some cracking at the nose under rub rail. I know the drain plug is bad and there is a bad fibreglass job in one corner of the floor near transom. Might have to rip the floor up too but it feels solid everywhere and is painted a Matt looking black. I would like to make it look nice with no rub rail. Thanks in advance.
    Some pictures only ones I have it's put away for winter.
    Pekin, IL
    Welcome to the site. Nice looking boat. I would not remove if the transom area is all that needs repair. Cracking under the rub rail may just be filler and is fairly common. Good luck.
    Rock
    Team Junk
  1. Fixing my Transom angle 18.5 Raider welded aluminum
    By Madmac74 in forum Technical Discussion
    Last Post: 08-30-2019, 09:00 PM
  2. fixing transom to top seam on old witchcraft
    By colinJ in forum Fiberglass and Composites Discussion
    Last Post: 07-02-2018, 05:37 AM
  3. Advice on fixing damage to top side of hull
    By RSWORDS in forum Fiberglass and Composites Discussion
    Last Post: 05-08-2017, 12:35 PM
  4. Mercury Tech: Need advice - remove frozen tilt tube
    By activator22 in forum Technical Discussion
    Last Post: 04-17-2013, 05:57 PM
  5. Looking For Advice On Fixing Damage
    By TwzteD in forum Fiberglass and Composites Discussion
    Last Post: 04-07-2010, 06:44 PM
