Results 1 to 15 of 34
Thread: 1647-5675 housing
12-05-2023, 05:53 PM #15000 RPM
- Dec 2017
- sam rayburn lake...east texas
- 135
- 13
- 7
12-05-2023, 07:23 PM #2
i'd scrape it.. mainly cause it had ta have tha carrier pinned for some unknown reason....
12-05-2023, 08:32 PM #3
Did they ever "pin" them when they coned or rebuilt them, to prevent damage or only after the carrier spun?
I still have one coned case with the keyway torn out that I haven't tried to fix yet.
I fear all we have done is to awaken a sleeping giant and fill him with a terrible resolve.
OnPad liked this post
12-05-2023, 09:26 PM #4Member
- Nov 2018
- Central Pa
- 93
- 11
- 66
David - WI thanked for this posttlwjkw liked this post
12-06-2023, 03:02 AM #55000 RPM
- Dec 2017
- 135
- 13
- 7
12-06-2023, 03:25 AM #65000 RPM
- Dec 2017
- 135
- 13
- 7
The gears were bad, all I saved was the drive shaft and shims gear end is smaller than a mercury drive shaft
12-06-2023, 03:29 AM #7
12-06-2023, 03:52 AM #8
Could it possibly be an XR4 case? What is the diameter of the bullet? 4 1/4" or 4 3/4"?
Is there a retainer nut for the driveshaft under the water pump base? If not, it is an old preload pin case.
Pull out the forward gear and look for a part number on the gear. Search the part number to try and identify the gearcase.
12-06-2023, 05:55 AM #95000 RPM
- Dec 2017
- 135
- 13
- 7
That is the parts number on the housing, same place as mercury, let me know if you find anything 1647-5675
12-06-2023, 06:19 AM #105000 RPM
- Dec 2017
- 135
- 13
- 7
12-06-2023, 04:12 PM #11
12-07-2023, 02:30 PM #12
It is an XR4/XR6 case. Small bullet. Don't scrap it unless the bore where the carrier rides is warped. Yes some pin the drag race cases as preventative especially when they are just made to do 1/4 mile pulls. Did the case have a reverse gear in it when you pulled it apart?
David - WI liked this post
12-07-2023, 06:37 PM #13
this is an early XR6.. (bobby v. built for me a long time ago)... notice how tha cavitation plate extends past tha tail end.. tha XR4 case it stopped even with tha tail end.. justa easy way ta tell tha difference (XR4 or XR6) if it is actually a small dia. case............
12-07-2023, 06:56 PM #14
And the casing 1647-5675 is not the later casing. If its xr4 then its gonna be the version where the cav plate does not extend. If the cav plate extends then It has to be an I-6 case. Either way I wouldn't scrap it...the bore looks ok, so someone would want it.
12-07-2023, 08:44 PM #155000 RPM
- Dec 2017
- 135
- 13
- 7
All have is a drive shaft, no gears I need all the in side
Mercury Tech: Mercury lower unit 1647-9147-C1
By cactusth in forum Technical DiscussionReplies: 12Last Post: 08-06-2018, 03:02 PM -
NOS Case. 1647-6049 Preload?
By bullet123 in forum Lower UnitsReplies: 5Last Post: 05-25-2018, 04:39 AM -
mercury lower unit 1647-9147
By texasvector in forum Technical DiscussionReplies: 1Last Post: 06-05-2016, 09:36 PM -
1647 9147-c
By xb03fs in forum Technical DiscussionReplies: 0Last Post: 05-01-2014, 07:28 PM
