Results 1 to 15 of 16
Thread: 2.4L Chrome 175 "Funny" Sound
09-16-2023, 06:55 PM #1
I have a rebuilt 175 - new pistons, rings, rods, 15 over steel sleeve in #1. It's just broken in. I put one size bigger main jets in the carbs just to be safe. It is a drop-on powerhead that is replacing a 2L XR2 150 (which runs great), I just wanted the extra torque. The extra top speed is just a bonus. This 175 runs great at high throttle positions, but at slower cruising speeds it runs kind of "ratty." It has a harmonic sound coming from it, kind of like one hole is firing differently than the others, or it also kind of sounds like bearing noise. Not loud and alarming, just not "right." My 150 does not make this sound. It also doesn't run very smoothly at displacement speeds, compared to my 150. Carbs were gone through, new floats, set float height, new needles, they look really good. Any ideas what this could be? I don't want to just start changing parts w/o some idea of where to start. TIA!
09-19-2023, 07:38 AM #2
Member
- Dec 2021
- NV
- 41
- 9
- 26
I am not an expert by any means. I have rebuilt my 175 (1985 chrome bore) recently. I do not have any funny sounds. Hopefully you used Locktite Red on the rod bolts and made sure the rod caps were aligned properly to the rods. If that was all good then I would suspect carburetion or sync & Link and timing settings. I had an issue where after rebuilding the carbs, the float bar screw was loose and flooded one cylinder. This was my bad but the motor ran pretty good in that condition till I diagnosed it. Just a thought. Runs better now of course.
09-19-2023, 11:08 AM #3
Member
- Sep 2021
- Buffalo, NY
- 85
- 283
- 18
Not sure you're going to notice any top speed difference between a normal 175 and a hot 150. They both basically make the same HP at the prop.
09-19-2023, 09:00 PM #4
09-21-2023, 12:35 PM #5
Team Member
- May 2009
- 1,843
- 537
- 70
- 611
- 290
- 6 Post(s)
This is what I would expect, too.
I have a 2.4/200 and a 2.0/150. And run them on the same boat. The extra displacement of a 2.4/200 over a 2.0/150 can be felt.
I don't have a 2.4/175, But I'd bet that the extra 25 hp that a 2.4/200 holds over a 2.4/175 is mostly felt at the very top end, (where I rarely go in my recreational usage). In fact I wonder if the 2.4/175 might be torquier than the 2.4/200?
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
09-21-2023, 01:59 PM #6
Member
- Sep 2021
- Buffalo, NY
- 85
- 283
- 18
09-21-2023, 03:53 PM #7
XR is just mainly a merchandising badge.. they do have a coupla things (carburetor's, tuner two main things) that spice it up a little but not much.... lotsa stories out there................. jmo.
09-21-2023, 04:36 PM #8
Member
- Sep 2021
- Buffalo, NY
- 85
- 283
- 18
09-21-2023, 04:46 PM #9
yeah, forgot about that for some reason
cause thats all i ran (XR6) on my hot rods back in tha day.......
09-21-2023, 11:29 PM #10
There is a big difference between a regular 150 and an XR150. There is the different carbs and tuner. They use a different throttle cam. They have the small bullet lower unit with a 1.87 ratio instead of a 2 to 1 ratio. But the biggest difference is the XR150 uses a 2.4 liter block like the 175 and 200. not a 2.0 liter. They have a little more horsepower than a regular 150. But they have a lot more low end torque.
09-22-2023, 02:30 AM #11
Team Member
- May 2009
- 1,843
- 537
- 70
- 611
- 290
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
09-22-2023, 03:49 AM #12
Lesson for tha day.............
He only has half a clue.. first there are 3 different XR series motors.. true all tha XR series are 150's but all different.. first XR2 150 was 2.0 motor.. it had different carbs and tuner from tha "production 135/150 but uses same rotating assy... ALL 2.0 motors had standard gear case with 2 ta 1's.. tha XR4 is a 2.4 with tha small gear case with 1.78's (only production gears that fit tha small case).. its a not a chrome bore like tha 175/200.. tha 4 is the one and only "steel sleeve" (not chrome which makes tha 175/200 what they are) 2.4 merc ever made.. tha porting is no where close to tha 175/200.. they are notorious for tha sleeves being "turned" a scosh and not lined up with tha block porting.. no one knows (if they do they're not sayin') for sure if this is done intentionally or justa manufacturing flaw.. the small gear case had 1.78's and nothing else... 2 ta 1's were standard on tha 2.0 motor and 1.87's on everything else EXCEPT tha small case (XR4/XR6) which is tha 1.78's... XR6 (2.5) completely different from all tha rest.. small gearcase (1.78's) for first few years (why they got scarce in tha hot rod world) then went to tha regular case with mostly 1.87's...... a guy named Steckbauer machined tha 2 ta 1 stuff ta fit tha small case along with some other mods ta make 'em strong enough ta take a lot of HP... they are affectionally known as stecky's... most were non-shiftable... those cases are really hard ta come by now.. don't think anyone else is doin' it anymore although i think someone is or was makin' a billet carrier for it.....
there all kinds a stories 'bout tha XR series motors as for them being "something special" jus gets exaggerated in my opinion.. they do perform a little better than tha "factory" motors mostly but not by much...... but there's nothin' ta compare tha XR4 to since its tha only steel sleeve 2.4 they ever built!Last edited by tlwjkw; 09-22-2023 at 07:09 AM.
pcrussell50 thanked for this post
pcrussell50 liked this post
09-22-2023, 08:43 AM #13
Member
- Sep 2021
- Buffalo, NY
- 85
- 283
- 18
So maybe an xr2 would be a different story but I dont think I would notice any speed difference going from my xr4 to a 2.4 175
09-22-2023, 08:59 AM #14
if you don't then ya have something amiss somewhere.............. a healthy 2.4 175 will run really close to tha 200....... jus cause its a "2.4" they are completely different..
09-22-2023, 07:04 PM #15
Old school "sound of the drags"
By Robby321 in forum The Scream And Fly LoungeReplies: 0Last Post: 11-16-2015, 10:21 PM -
The real truth, the "transmission" exlpained. (funny, BACK THE DRINKS AWAY, keyboard)
By Robby321 in forum The Scream And Fly LoungeReplies: 5Last Post: 05-30-2010, 03:04 PM -
OSS/SBI Biloxi "Smokin the Sound" 2010
By Pete B in forum General Boating DiscussionReplies: 11Last Post: 05-27-2010, 06:42 AM
