Results 1 to 1 of 1
Thread: Smartcraft fuel quantity issue.
09-16-2023, 08:25 AM #1
Member
- Sep 2019
- Saint Helena Island, SC
- 59
- 10
On the way to breakfast the other day and the fuel readout began dropping quickly. I had recently filled the 60 gallon tank. In maybe 90 seconds it steadily dropped to 0 and triggered a LOW FUEL alert.
I stopped the boat thinking I had a massive fuel leak. I checked the bilge and nothing, not even the smell of gas. Cranked it back up and continued on. On the way back home I watched the gauge climb back up to 96% steadily.
Next time out it read 0 from the start and had not recovered.
From what I’ve read a fuel sender should have @ 240 ohms of resistance when empty and 33 when full, so an open circuit would result in a 0 reading. I also noticed the trim indication tends to “float” a bit after I release the trim switch where it used to be rock stable. The motor does not move after trimming, just the indication.
I’m wondering if a bad ground somewhere could cause both issues as they both began at the same time? I did check and clean both sets of battery terminals. Getting 12.3 volts engine off and 14.1 with it running. Voltage is steady.
Anybody had similar symptoms?
2007 300xs odd fault/smartcraft issue.
By 288sunny in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 09-10-2019, 03:06 PM -
Smartcraft Fuel Alarm
By CMC in forum Technical DiscussionReplies: 11Last Post: 08-07-2019, 10:12 PM -
2002 225 EFI Fuel issue/Where to get fuel pressure guage with Schrader adapter
By Rio Sunset in forum Technical DiscussionReplies: 3Last Post: 09-27-2018, 05:39 AM -
Mercury SmartCraft fuel/oil
By aeneas in forum Electronics, Audio Systems, and WiringReplies: 2Last Post: 08-11-2013, 10:03 AM -
Need to Find Reasonable Quantity of Monel or Stainless Divergent Point Staples
By Li'l Toy in forum General Boating DiscussionReplies: 11Last Post: 04-08-2012, 10:35 PM
