Results 16 to 30 of 31
09-18-2023, 08:25 AM #16
Junior Member
- Jan 2018
- Lake Charles, LA
- 12
Mrzip liked this post
09-18-2023, 09:53 AM #17
I am coming up with different number. Four 3/16" holes added together is one .375" hole (3/8" hole).
I could be wrong but formula is: Diameter of one of the drilled holes x Square Rood of the number of holes total. (.1875x SqRt(4)=.375)
Either way I would work more on water temp VS water pressure.1973 Viper - sold
1978 Viking - will be sold
1995 XB02
09-18-2023, 01:29 PM #18
Junior Member
- Jan 2018
- Lake Charles, LA
- 12
Okay i was doing (4 holes) x (3/16) equals (12/16) which in simplest form is (3/4) I had talked with dwayne roberie and he recommends 22 lbs but yes i agree. His temp problem could also be coming from no diverters? I know what i have now is working so hell eventually get it
rjdubiel liked this post
09-18-2023, 01:53 PM #19
The Historic Photo Master
- Jan 2004
- Florida
- 36,934
- 59
- 1598
- 307
- 18473
- 3 Post(s)
09-18-2023, 04:01 PM #20
Junior Member
- Mar 2023
- Savannah Ga
- 7
Going to pull my heads to check for diverted here soon
09-18-2023, 04:01 PM #21
5000 RPM
- Aug 2006
- GA
- 838
- 30
- 64
Fujimo. That's It.
09-18-2023, 04:02 PM #22
Junior Member
- Mar 2023
- Savannah Ga
- 7
What is the recommended hose to use for diverters
09-18-2023, 04:02 PM #23
Junior Member
- Jan 2018
- Lake Charles, LA
- 12
Good deal let us know we will get it figured out RJ D is good with this stuff, He helped me with my 280
09-18-2023, 04:03 PM #24
Junior Member
- Jan 2018
- Lake Charles, LA
- 12
I found 1/4 worked well for me it was tight
09-19-2023, 06:50 AM #25
Do you stuff the hose down all the way then cut flush or?
09-19-2023, 07:27 AM #26
No, you need to leave room on each side for water to flow all the way around the hose diverter you put in. They go in 3 and 5 at the 10 oclock position 2 and 4 at the 2 oclock position (shown in the picture above). Cut them 1/4" shorter than the total depth of the water jacket leave 1/8" on the top and the bottom of the diverter. Water needs to flow around the diverter. Nice soft 3/8 cheap auto store fuel hose works. Marine stuff is too big or OD. 5/16 hose even fits good.
I put them in all motors, steel, nikasil, chrome.1973 Viper - sold
1995 XB02
09-20-2023, 01:28 PM #27
I use the length of the 200xs
09-21-2023, 01:03 AM #28
i did the same thing 7 or 8 years ago.. put on a 1 piece plugged orignal holes redrilled and just added 1 hole on each side.. not 2.. but i have no water pressure at idle and none comes out the heads unless reved up and just slightly dribbles.. and have 60psi water pressure at shop.. but soon as i put it in water sumerged it starts peeing instantly.. motor runs 15-18psi at wide open throttle and 140-145 temp perfect all the time.. motor is a cut up 225 promax with 2.4 bridge port front half to fit.. 260 horn and 16 amp flywheel and electronics.. also to add motor never gets hot on hose though it dont pee so pretty weird but find a solution id be curious to know my self...
1979 hydrostream vector sold
2001 american offshore 26 twin 300 promaxs
2006 hydrostream comp vking horned 225 promax/
1986 23ft twin engine eliminator twin 225 promaxs SOLD
Kitch liked this post
09-21-2023, 01:07 AM #29
Junior Member
- Jan 2018
- Lake Charles, LA
- 12
09-21-2023, 02:23 AM #30
yessir i do i can help you with it ... stephen mcdonald..
Mercury Tech: 2 piece plate for 225 promax on 15 mid?
By simpson_3 in forum Technical DiscussionReplies: 2Last Post: 03-17-2022, 04:49 PM -
Low water pressure with my 1 piece adapter
By rkmirage in forum Technical DiscussionReplies: 7Last Post: 08-27-2016, 07:36 AM -
Mercury Tech: 225 promax on a 1 piece plate
By Dark Allison in forum Technical DiscussionReplies: 8Last Post: 12-03-2008, 02:56 PM
