Results 1 to 5 of 5
Thread: Verado info needed
09-07-2023, 06:53 PM #1
Verado info needed
I'm looking to maybe upgrade my pontoon engine from a 2012 I4 200 Verado to a 300 or 400, my motor has DTS controls but uses SeaStar steering with a SeaStar power assist pump. I'm asking these questions because changing the rigging in this boat is difficult, it's under shielded with aluminum and the wiring is complex so I would prefer to change nothing.
Hoping for plug and play?
I found a new 300 V8 (not a Verado) at a local dealer, he tells me I need to change my controls, but he "thinks" the main harness is the same and my steering will work. He says if I go with a Verado, new or used I will have to change my steering? I realize the hydraulics for the bigger Verado's is built into the clamp bracket but why won't the SeaStar hoses hook up to that and make it functional?
Running shift and throttle cables to a standard 300 V8 is doable but changing the ignition harness will absolutely suck and I don't want to do that.
09-07-2023, 07:51 PM #2
The Sea star will work with verado Ram .You need to change fittings on the merc end.
24 Twister
09-08-2023, 08:05 AM #3
Go with a CMS bracket DTS engine. Everything will work. We done a few.
2012-2013 DSRA PRO STOCK HIGH POINTS.
2013 DSRA SUPER STOCK HIGH POINTS.
2014 DSRA SUPER COMP HIGH PONTS.
2015 DSRA SUPER COMP HIGH POINTS.
2014,15,16 ODBA SUPER STOCK WORLD CHAMP.
2016 ODBA SUPER STOCK HIGH PIONTS.
2017 ODBA Modified World Champ
09-08-2023, 08:50 AM #4
Is the CMS motor the newer motors? I’ve been mostly looking at used I6 Verado’s. Hard to find them up here, most are along the coast and FL. I want a 20” and that also is hard to find. Guy up here is selling a pair of 400r’s, all I need to do is change the fittings on the clamp bracket and everything else will plug in?
My 200 has 207 hours, what is that worth?
09-08-2023, 04:55 PM #5
Check your PM 400R will not work with your older DTS you can use part of it .But it is not plug and play. Give me a call to much to type
24 Twister
Need info on lifting eye for 4 stroke 150 carb motor- non Verado
By CircleHook in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 3Last Post: 03-17-2017, 04:26 PM -
Mercury Tech: Verado lower unit info
By Go Time in forum Technical DiscussionReplies: 1Last Post: 09-16-2014, 04:51 PM -
Deciding setback Optimax 300xs vs Verado 300/350 sci - technical info
By Toffen in forum Props, Setup, and RiggingReplies: 1Last Post: 09-11-2010, 11:11 AM -
ECU info needed....
By mikiedreb in forum Technical DiscussionReplies: 4Last Post: 10-05-2004, 06:20 PM
