Results 31 to 42 of 42
Thread: 1989 Mariner 175Ski
09-17-2023, 10:13 PM #31
Team Member
- May 2009
- 1,769
- 483
- 66
- 545
- 279
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
Glastron1987 thanked for this post
OnPad liked this post
09-18-2023, 11:51 AM #32
I have seen them both ways. Not real sure why but it is a factory thing.
RockTeam Junk
09-18-2023, 01:42 PM #33
Interesting,..... That hole would lead directly to the main water feed, before it made it to the top of block, on the 1990 engine I'm looking at.
At this point I think Glastron1987 would be wise to drop the lower again and check his work, or for any missing parts. It gets easier the more times you do it. If you can't find a helper, use a piece of wood to jam the case up (third hand) while you fiddle with water tube, driveshaft, and shifter. Leaving it in gear will allow you to spin the propshaft, helping align your driveshaft splines. When you have the l/u off you can remove the pipe plug you were asking about earlier, install a garden hose in that hole. While trimmed up, you may be able to back flush sand /gravel out the intake side of adapter plate.
A idling engine should fill to the top of both heads, (or the plug in the top of block) in about 20 seconds at the lake, probably faster on the hose with proper fitting muffs. Likely never with poorly fitting muffs. Once the engine is full it takes a few minutes for the thermostats to open.Last edited by OnPad; 09-18-2023 at 07:39 PM.
Glastron1987 liked this post
09-18-2023, 06:36 PM #34
5000 RPM
- Oct 2008
- Plainville, CT
- 720
- 360
- 21
- 340
- 51
I like the idea of once getting past the overheat problem taking it for a ride and seeing if compression comes back and if not take the scotchbrite to it. I'm still confused about the small hole though because Rock says he's seen them opened and blocked. Per Onpad I probably do need to take the LU off again and test that way.
09-18-2023, 06:37 PM #35
5000 RPM
- Oct 2008
- Plainville, CT
- 720
- 360
- 21
- 340
- 51
09-20-2023, 06:16 AM #36
I believe Rock,... and also like the idea of blocking the little hole off, like skialot recommended. It's a leak directly down the poppet dump. Not unlike the hose from poppet cover to top of engine on later model stuff, but in a less ideal location. Maybe not enough to keep the block from filling with a operational pump, but it isn't helping. That little hole isn't far from your pump. If your having problems getting water there, you got no chance at the top of the block. We're only talking like 6 or 19 oz.of water above pump to that hole. How does a garden hose not fill the block with tight fitting muffs, properly installed (rotating) water pump and feed tube??? My guess is something isn't right in the water pump/feed, or plugged adapter plate.
The test pcrussell showed a video of is legit. Good for testing if your getting water through the block, or dislodging crud in adapter. If you were to momentarily apply water this way, then let drain, it could back flush junk out of the adapter that collects at the first low spot. Kinda the reverse of the method I mentioned a few posts back.
this is where all the pebbles and fishing sinkers get stuck between the two plates.
Was your poppet, and associated parts present?
How are you feeding the engine water, ...muffs, trough, or lake? Your muffs good n tight?
09-20-2023, 06:32 AM #37
... i have, as you, seen tha hole in a few motors.. jus never paid much attention to it...... sometimes ya jus gotta wonder what merc engineers were thinkin'...........
jus gonna add..
if its got tha hole then you would think tha plate/plates may be a little different maybe???Last edited by tlwjkw; 09-20-2023 at 07:09 AM.
09-20-2023, 02:25 PM #38
5000 RPM
- Oct 2008
- Plainville, CT
- 720
- 360
- 21
- 340
- 51
09-20-2023, 02:33 PM #39
Might need to dip it in the crick. I have had motors show nothing on the muff but be fine in the water. Pump and lower being submerged makes aa difference on some of them.
RockTeam Junk
09-20-2023, 05:50 PM #40
5000 RPM
- Oct 2008
- Plainville, CT
- 720
- 360
- 21
- 340
- 51
09-20-2023, 05:59 PM #41
09-21-2023, 07:12 AM #42
5000 RPM
- Oct 2008
- Plainville, CT
- 720
- 360
- 21
- 340
- 51
1987 Mariner 150 1989 Mariner 175
By Gilles1 in forum Technical DiscussionReplies: 1Last Post: 08-10-2007, 07:56 AM -
1989 mariner 70
By Nik Bencini in forum Technical DiscussionReplies: 1Last Post: 08-01-2005, 07:46 PM
