Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
Results 1 to 15 of 138
    Plainville, CT
    1989 Mariner 175Ski
    Picking up a 1989 Mariner 175Ski. Engine looks pretty clean. Appears to be a 2.4L XRI system engine.
    Owner says he's been running for years with a small knock.
    First of all, any comments about this model engine? Anyone have one?
    Second, any ideas on what a small knock might be?
    I'm think it could be anything simple like a clogged injector, to a full rebuild required.
  2. Likes Aaronhl liked this post
    Pekin, IL
    A knock on 2 stroke is not usually a good sign and rarely do they run "for years". I would look for something like flywheel contacting something or something else loose. If it is internal be careful.
    Rock
    Team Junk
  4. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, sonicss33, OnPad liked this post
  5. #3
    Jul 2011
    Peterborough, On
    I blew one up last year, was a good performer up to that point. I had a 2.4 200 xri before it, and key differences were 2:1 lower unit and a different shaped throttle cam. I was told those 2 were to get a skier out of the ditch quickly and give the driver decent low speed management. Have the knock diagnosed and if easily fixed, it'll be a solid performer.
    1989 Canadian Edition Vision Sold
    1990 Hydrostream Virage Stage 3 Turbo
  6. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  7. #4
    Plainville, CT
    Quote Originally Posted by idvette View Post
    Good info, thanks.
    Jun 2009
    Bristol, Connecticut
    Did you take those spark plugs out yet
    Lake Coochiching, Ontario
    from a 1989 Mariner brochure:
    175 ski 2:1 gears, 5000-5600 max rpm, 398 lb
    175 carb, 1.87 gears, 5300-5800 max rpm, 382 lb
    200 carb, 1.87 gears, 5400-5900 max rpm, 382 lb
  10. Thanks Glastron1987 thanked for this post
  11. #7
    Plainville, CT
    Quote Originally Posted by David View Post
    Interesting
  12. #8
    Plainville, CT
    Quote Originally Posted by Aaronhl View Post
    Not yet. Have to get it home first.
  13. #9
    Plainville, CT
    Spark plugs look good. Except plug #1 looked just very slightly dirtier. No aluminum on any of them.
    Did compression test and 5 out of 6 were fine. #1 was very low.
    Took head off and appears head gasket at the top was bad... leaking compression into the water jacket. Otherwise, all parts look fine.
    I may have gotten lucky with this engine.
    Will replace the head gasket and see how it runs.
    Question... What do I put on the new head gasket so that it will come off OK in the future, or do I put it on dry?
    Pekin, IL
    dry. oil threads on head bolts
    Rock
    Team Junk
  15. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, sonicss33 liked this post
  16. #11
    Plainville, CT
    Quote Originally Posted by rock View Post
    Rock
    Thanks.
    Plan to use 2-stroke oil on the bolts and torque to 35lbs in an alternating pattern starting from the center going out and do it a little at a time.
  17. Likes rock liked this post
  18. #12
    Plainville, CT
    Little disappointed after replacing the head gasket. Compression did improve from about 45psi to about 80psi, but probably I'll try replacing that piston and rings to get it closer to 120.
    In any case, it seems to start up and run fine, except there is this little hose at the top of the block that I don't know what to do with. After the engine is warmed up it dripples water out of it. On some engines, it might be attached to the poppet, but I see no connection for that on this poppet. Attached are photos. Any ideas?
ID:	523700Click image for larger version.
  19. #13
    Nov 2021
    N. Idaho
    Sometimes a overnight soak with seafoam, will free stuck rings.
    The hose at the top of engine is for a water pressure gauge. You can block it off, or better yet install a gauge.
  20. Thanks Glastron1987 thanked for this post
  21. #14
    Plainville, CT
    Fantastic. I'll try the soaking and for now will block it off. Thank you.
  22. #15
    TX......somewhere?
    looks like you have one of tha very first of tha water cooled reg/rect. motors... first '89's didn't have tha hose from top down to tha poppet.. that came later in tha year model ('89) ta help keep tha reg/rec cool.. yours is for an added water pressure gauge....
  23. Thanks Glastron1987 thanked for this post
  1. 1987 Mariner 150 1989 Mariner 175
    By Gilles1 in forum Technical Discussion
    Last Post: 08-10-2007, 07:56 AM
  2. 1989 mariner 70
    By Nik Bencini in forum Technical Discussion
    Last Post: 08-01-2005, 07:46 PM
