Results 91 to 105 of 138
Thread: 1989 Mariner 175Ski
11-19-2023, 07:32 PM #91
you need ta look at tha head and tha deck surface.. you will need a good/accurate straight edge... we have reused head gaskets (ones that were never over heated) many times over tha years without a problem... tha o-rings, not so much...
but at tha same time we mostly used regular heads and gaskets on our motors (had ta deck tha blocks 'bout 40 thousands also) that originally had o-rings.. was to expensive to cut tha o-ring head ta get tha compressiopn we were lookin' for back then...Last edited by tlwjkw; 11-19-2023 at 07:43 PM.
pcrussell50 liked this post
11-19-2023, 07:38 PM #92
I heard that it is the original thermostat location from Jerry Hale. RCKID74 on this site. He was the project engineer for Mercury's (Black Max) 2 liter V6. You can read all about it on this site. It is in a sticky in "Outboard and Racing history" called "Merc V6 History" started by warrior74z in 2007. It's somewhere around 15-20 pages in. It's one of the best reads on this site. Lots of cool information.
Glastron1987 thanked for this post
OnPad liked this post
11-19-2023, 07:49 PM #93
if they in fact did it never went into production............. tha very first 1976 175 2.0 V6 on tha market had stats in tha heads................
one thing 'bout tha 175"ski" is thats its built from tha only steel sleeve 2.4 motor (XR4 rotating assy and only with tha mariner badge) merc built.. it seems like it (steel sleeve 2.4) was just an experiment that used tha public for their R and D...... jmo.Last edited by tlwjkw; 11-19-2023 at 08:49 PM.
11-19-2023, 08:05 PM #94
jus another note.. that "extra hole" seem ta appear at tha same time they realized they had a coolin' problem with tha water cooled rec/reg... they may have been lookin' for any way possible ta help with its (rec/reg) problem... jmo
11-19-2023, 08:15 PM #95
11-19-2023, 08:44 PM #96
jus that something doesn't add up with that hole (which seems synonymous with tha XR4 block), 2 and 4 bolt poppets.. everything had a two bolt with first gen blocks.. then came a 4 bolt for a time then back to two bolt and then tha 4 bolt again.. i know why tha 4 bolt with tha hose goin' to tha top of tha block came about (and has stayed around tha longest) and what its for but don't have a clue as to why tha other changes were made.... jus never questioned it... they either worked or they didn't.. if they didn't, replace with what ever it called for... jmo.
11-20-2023, 07:37 AM #97
5000 RPM
- Oct 2008
- Plainville, CT
- 765
- 388
- 22
- 354
- 60
Would putting a little antisieze on the head gasket be a no-no so that it comes off easier and keep in in better shape for reuse?
11-20-2023, 10:01 AM #98
dry.. justa a touch of 2 stroke oil on tha bolt threads..... did ya check tha surfaces for being flat?
11-20-2023, 12:02 PM #99
11-20-2023, 12:43 PM #100
Actually, I looked it up. according to the schematics the original 2.0L V175 first poppet design was a 4-bolt design. Part # 68729(#3) It has the hole for a nipple, but it is not shown. Probably uses a plug.
The second poppet design was a 2-bolt design. Part # 66563A1(#6) No hole for barb
The 3rd design went back to a 4-bolt design. Part # 14462A1(#17) Comes from the factory with the hose nipple.
11-20-2023, 01:02 PM #101
had it backwards but i'm old and no books ta read... so glad ya got all that straightened out.. some had a nipple and some didn't.. no mater what merc wasn't consistent with a "single" poppet design that would probably work in any of tha V6 blocks.. its like they were just experimenting with 'em.. but merc was famous for **** such as that back then...... even more so in tha hi perf. division............. jmo
still think tha reason for extra small hole is in some way connected to tha 40 amp rec/reg coolin' problems.. they were gettin' air pockets (normal) in tha system that caused tha problems with it... seems ta be thats when it showed up...........Last edited by tlwjkw; 11-20-2023 at 01:20 PM.
11-20-2023, 05:34 PM #102
Team Member
- May 2009
- 1,843
- 537
- 70
- 611
- 289
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
11-20-2023, 05:37 PM #103
exhaust in the pee hole or steam??
I wouldnt put anti seize anywhere near a head at risk of getting in the head bolt holes and i have found that to be a problem finding correct torque...
11-20-2023, 06:07 PM #104
Team Member
- May 2009
- 1,843
- 537
- 70
- 611
- 289
- 6 Post(s)
This is legit.
The purpose of torquing correctly is to get the specified preload on the head bolt. If you are torquing with unspecified lubricants or bolts not specified in the manual, you are then guessing on the preload.
That said, on my 2.4/200 I used anti-seize on the head bolts. I check it frequently for loosening. I understand that I have no way to know if it’s over torqued.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
11-20-2023, 08:51 PM #105
5000 RPM
- Oct 2008
- Plainville, CT
- 765
- 388
- 22
- 354
- 60
Took the head off again, and I saw no sign of water breach, and the head and block look flat. I seriously think there is some other issue causing such a severe loss of water pressure.
1987 Mariner 150 1989 Mariner 175
By Gilles1 in forum Technical DiscussionReplies: 1Last Post: 08-10-2007, 07:56 AM -
1989 mariner 70
By Nik Bencini in forum Technical DiscussionReplies: 1Last Post: 08-01-2005, 07:46 PM
