Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    Jun 2023
    Texas
    Quote Originally Posted by Baker343 View Post
    Let me back up. Check the last 3ft of running surface to make sure your hull doesn't have a hook
    I'll check it again but when I used a long straightedge to measure the prop to pad it looked good.
  2. #17
    Jun 2018
    Floating around
    Have you done a black box delete? Oil injection delete? If not do both
  3. #18
    Jun 2023
    Texas
    Oil injection delete is done. I do not think this gen XR6 can have a black box delete like the earlier ones; the only black box on the motor is for the ignition system.
  4. Likes LakeFever liked this post
  5. #19
    Jun 2023
    Texas
    So as an update there will be more testing tomorrow:
    - I am going to try the same Trophy Plus 25P at 3.25" prop-to-pad which is as low as the jackplate will go without remounting the engine. That's lower than the lowest from the first round of testing.
    - Then I am going to switch to a practically brand-new Tempest Plus 24P I just scored and incrementally raise the jackplate from there.
    - Test conditions will be close to the same as before. Lake, temperature, wind, boat load.
    Then I'll come home and crunch the data, think about it, pick the prop, and sell off either the Trophy or the Tempest. Again I already have a 21P Trophy+ for slower and heavier work; this testing is for the go-fast, fishing-solo prop.
  6. Likes LakeFever liked this post
  7. #20
    Jun 2023
    Texas
    Well... That prop test did not happen today. A testing trip with two ended up being a fun trip for four so I reinstalled the 21P Trophy+ and we cruised and tubed around on that all day.
    What I did confirm is that with four adults in the boat, 30 gallons of gas, and miscellaneous gear that the 21P Trophy+ will definitely work as the heavy load all-purpose prop. It topped out at 50 MPH (gps) at 5800 rpm with four in the boat, and at 45 mph with three in the boat and one being towed on the tube.
    Again this XR6 is set up by Mercury not to run above 5800 rpm so I believe that 50 mph wall was an rpm limitation and not a drag limitation; in other words, 21P was not too much prop. With a light load it would be too little (but I knew that already).
    I'll report back when I complete testing with the other two props.
  1. what prop to try next? Johnson 110 17 foot aluminum w/ jack plate
    By leaky in forum Props, Setup, and Rigging
    Last Post: 06-22-2015, 02:56 PM
  2. Prop Change and Jack Plate...Gains??
    By badbowtie03 in forum Technical Discussion
    Last Post: 06-28-2012, 06:56 PM
  3. What jack plate, prop etc..
    By MikeW_Tx in forum Props, Setup, and Rigging
    Last Post: 05-04-2008, 09:00 AM
  4. prop for boat with jack plate
    By jcraft in forum Technical Discussion
    Last Post: 01-07-2005, 09:32 PM
