Results 1 to 6 of 6
06-03-2023, 02:26 PM #1Member
- Jul 2020
- Connecticut
- 30
Optimax. Unplugged wire, plug it back in?
I was checking the thermostats on my optimax. All is well there but I noticed this wire unplugged. Not sure if I did it or if was already unplugged prior. Working on these is somewhat new to me so I’m taking it one step at a time.
should I plug it back in or is purposely unplugged? Thanks in advance for the help, mechanics are impossible to get this time of year so I’m taking on much more than I have in the past. Good news, I’m handy and don’t my asking questions.
06-03-2023, 05:41 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Temp sender for air pump. Plug them in. The overheat warning system averages the temps of each sender for the pcu to adjust to temp for best operation. Fuel enrichment etc. Solid tan one can be used as a temp sender for a gauge.
06-03-2023, 05:56 PM #3Member
- Jul 2020
- Connecticut
- 30
06-03-2023, 06:19 PM #4Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
The pee stream is from the air pump. Check the temp of the water coming out. If it feels hot, you may have a clogged intake screen. Hose from air pump goes down on lower port side of engine to screen / nipple fitting. The t-stats open at 130-140.
You have a temp gauge? They run about 140 normally.Last edited by XstreamVking; 06-03-2023 at 06:22 PM.
06-03-2023, 08:09 PM #5Member
- Jul 2020
- Connecticut
- 30
06-13-2023, 05:12 PM #65000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
You can get a temp gun at Harbor freight for 30$
Plug wire fit
By ChopperDr in forum Technical DiscussionReplies: 4Last Post: 05-11-2022, 11:06 PM -
‘06 Mercury Optimax plug wire type testable?
By Motv18 in forum Technical DiscussionReplies: 0Last Post: 02-23-2018, 02:11 AM -
Plug wire ?
By 18ftswitzer in forum Technical DiscussionReplies: 5Last Post: 11-08-2010, 01:38 PM -
plug wire
By Riverratt in forum Technical DiscussionReplies: 10Last Post: 04-12-2008, 08:32 AM -
Plug Wire's
By 175checkmate in forum Technical DiscussionReplies: 13Last Post: 08-27-2002, 04:30 AM
