Results 1 to 14 of 14
    I live in Prineville Oregon which is in the central part of the state
    Nosecone speedometer pickup question.
    Would this work? On a Bobs nosecone at the very top of the cone, where it is even with the top of a stock lower the metal is only about a quarter of an inch thick. If you drilled straight down into the cavity where the water is picked up and installed a small tube outlet would that water pressure be overpowering for a speedometer. I am thinking this would work. Any ideas would be appreciated.
    Many thanks, Carter Powell
    Jan 2003
    aalsmeer
    More trubble than it is worth
    a Gps speedo is not expensive
  3. Likes LakeFever, David - WI, NICE PAIR liked this post
    Nov 2021
    N. Idaho
    I bet it would work. You could calibrate with restrictors.
    Good idea!
    Mar 2023
    SW Florida
    A lot of lowers have pickup installed there. It is a big improvement over gps cuz it is around 10 mph faster. Which translates to 100 more hp. And no extra fuel!!
  6. Likes LakeFever, NICE PAIR liked this post
    I don't think that would work... the
    cooling system pressure is limited by the poppet valve? Speedo needs it's own inlet.
    Let's make America great again!
    Nov 2021
    N. Idaho
    Pre water pump from the poppet.
    Maybe you just end up with a extra 4" water pressure gauge, kinda?
    But the impeller just folds in at speed... I'm told.
    I have GPS in my other boat but I was just wondering if this would work. I have another boat that I am redoing and it already has a non GPS speedo in it. I was told that the pressure is the same whether it is a small hole or a larger one. Just an idea.
    thanks, Carter
    Nov 2021
    N. Idaho
    Your probably right about restrictors not working, as there is no flow out of sender tube.
    I think you ought to try it, and let me know.
    I have a couple boats, could use this.
    I build flush mount water pickups into the bottom of my model boats with ks brass tube, if your willing to drill a hole in the bottom of your boat, I'll tell you all about it.
    Nov 2019
    Canada
    Is there a reason you want to go to these lengths to retain a speedo that's not accurate? Can't you get a replacement speedo in GPS?
    www.InjectorService.com
    Call/Text - 204-326-0390
    Nov 2021
    N. Idaho
    This would be my reason. Retaining a vintage matching dash, with stuff already owned.
ID:	519698Click image for larger version.
    The one boat that I have a working mechanical gauge on is pretty accurate... If you can believe that.
    All that being said, I use my phone or sonar unit for gps speed.
  14. #12
    I have a transom mounted speedo pickup... just a p.o.s. plastic one that flips up if you run over something.
    They're like $5 and work with any pitot-type speedo, so why fool around making something in the lower unit?
    https://www.greatlakesskipper.com/fa...-pickup-sender
  15. #13
    Nov 2021
    N. Idaho
ID:	519700Click image for larger version.
ID:	519701Click image for larger version.
  16. #14
    The reason I wanted to try this is because of all the original gauges. The gauges are autometer and the speedo is already there. I know that GPS is the way to go but I was just wondering if somebody thought this method might work, that's all.
    Thanks, Carter Powell
  1. WTB medallion speedometer pickup
    By bill mason in forum Misc. Parts and Accessories
    Last Post: 07-27-2018, 10:53 AM
  2. Aftermarket low water pickup nosecone help
    By Mr Walker in forum Technical Discussion
    Last Post: 06-30-2006, 09:03 AM
