Results 1 to 3 of 3
    Apr 2020
    OC
    1992 Johnson 200xp help
    Engine will only fire up when it’s hooked up to the charger with 1000amps going through it. I replaced the battery and it’s still doing the same thing. It’s like the motor is not cranking fast enough to fire it up without the jumper.
    Jan 2003
    aalsmeer
    Quote Originally Posted by Bingerfang View Post
    Probably time for a fresh starter
  3. Thanks Bingerfang thanked for this post
    Sep 2013
    Eastern LI
    How are the battery cables? Tight? Clean connection? NEW? If they are from 1992 replace them... Then of course, get a starter..
  1. 200XP, Johnson GT
    By Jeepguy in forum Technical Discussion
    Last Post: 05-12-2019, 10:52 PM
  2. OMC Tech: 1992 evinrude 200xp problem
    By v8etr in forum Technical Discussion
    Last Post: 09-04-2009, 03:52 AM
  3. 1992 200xp carb swap
    Last Post: 08-26-2009, 08:52 AM
  4. 1992 evinrude 200xp jetting
    Last Post: 06-02-2009, 11:46 AM
  5. 1992 evinrude 200xp running rich
    Last Post: 05-25-2009, 09:24 AM
