Results 1 to 4 of 4
Thread: CMC jack plate question, help.
05-28-2023, 03:00 PM #1
I need to find a way to install a limit switch for height on a CMC jack plate. Any ideas will be greatly appreciated.
Thanks, Carter
05-28-2023, 04:18 PM #2
You can buy a waterproof limit switch on ebay cheap. Fab a small bracket to mount it on the fixed side of the plate. Put a bolt and/or small bracket through the moving side of the plate so when it reaches the height you want it cuts the up feed.
rgsauger liked this post
05-28-2023, 05:05 PM #35000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
Try to fab an adjustable switch or switch actuator mount. If you knew the motor height you wanted, you wouldn’t need a hyd jack plate. Therefore you probably don’t know where you want either high or low limit yet. And use relays. Probly goes without saying.
05-28-2023, 06:07 PM #4
Its a clever idea. Home made seastar pro tap sorta deal
Jack Plate question
By Dave95 in forum General Boating DiscussionReplies: 2Last Post: 10-15-2015, 01:49 PM -
Jack plate question.
By dblount in forum Props, Setup, and RiggingReplies: 10Last Post: 03-02-2015, 07:29 PM -
Jack Plate question
By sjcolwell2 in forum Props, Setup, and RiggingReplies: 11Last Post: 11-17-2013, 08:30 PM -
Jack plate question
By Wallby202 in forum Technical DiscussionReplies: 3Last Post: 12-30-2012, 05:36 AM
