Results 1 to 11 of 11
05-28-2023, 09:02 AM #1
3.0 Merc crankshaft bearing numbers
The chubby crankshaft rollers fell everywhere in the garage - how many per bearing assembly are there ??
What is the part number for the chubby rollers in case I lost a few?
What is the part number for the thin metal retainer ring that goes around the completed bearing?
Cant find my answers in the manual or parts lookups !!
05-29-2023, 02:00 PM #25000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
What is motor serial number?
05-29-2023, 03:48 PM #3
easy to find bearings. This is random 250 EFI https://www.mercruiserparts.com/bam/...32591/6994/180
Jim
05-29-2023, 06:33 PM #4
I can find the bearings - seems like the needles that make up the bearing are not sold separately, the clips for the bearings do not show in the diagram
05-29-2023, 10:09 PM #5
A rod bearing includes the needles and the cages. Says you need 2 per rod. The wrist pin bearings come in packs of 200.
Jim
05-29-2023, 11:00 PM #65000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
i think he needs the mains the way he asked about outer race.
05-30-2023, 08:55 AM #7
Yes my bad for not saying main yes i am referring to the crankshaft to block bearings no the connecting rods in anyway
05-30-2023, 02:50 PM #85000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
Expensive and not sold separately. You don’t wanna mix used bearings from another motor or mix bearings from another journal same motor. A lot of people say you don’t wanna run any old bearings. If crank comes out they say all new. I see near 100 bucks for 1 main in a 2.5.
05-31-2023, 08:39 AM #9
Thats what they say
I think I got all the chubby needle bearings - I counted 44
05-31-2023, 08:43 AM #105000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
You have the spacer-bearing holder. 22 to a side. So there should be 21 slots in each holder with 1 more roller between each holder. If 44 is correct number.
05-31-2023, 08:54 AM #11
It's not like the connecting rod to crank shaft cage where I can count the slots in the outer pieces
Going to put it together see how it fits with the 44
I counted 44 myself and thats how many I see in pictures on line for new bearings for sale
2.5L 260/280/300 Big Bearing Crankshaft
By tripower in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-19-2020, 02:25 PM -
200 HPDI Vmax Rod Bearing or Crankshaft Lower Bearing
By sailnaked6842 in forum Technical DiscussionReplies: 1Last Post: 08-21-2019, 01:48 PM -
bearing part numbers
By Ajskennels in forum Technical DiscussionReplies: 4Last Post: 04-15-2018, 03:24 PM -
280 sporty fat shaft bearing numbers help
By natemart94561 in forum Technical DiscussionReplies: 2Last Post: 06-03-2015, 01:56 PM -
280 Big Bearing Crankshaft
By chris gantt in forum Misc. Parts and AccessoriesReplies: 0Last Post: 07-30-2014, 10:37 AM
