Results 1 to 11 of 11
    Jun 2009
    Bristol, Connecticut
    3.0 Merc crankshaft bearing numbers
    The chubby crankshaft rollers fell everywhere in the garage - how many per bearing assembly are there ??
    What is the part number for the chubby rollers in case I lost a few?
    What is the part number for the thin metal retainer ring that goes around the completed bearing?
    Cant find my answers in the manual or parts lookups !!
    Mar 2023
    SW Florida
    What is motor serial number?
    Mar 2022
    Lake Travis Texas
    easy to find bearings. This is random 250 EFI https://www.mercruiserparts.com/bam/...32591/6994/180
    Jim
    Jun 2009
    I can find the bearings - seems like the needles that make up the bearing are not sold separately, the clips for the bearings do not show in the diagram
    Mar 2022
    Lake Travis Texas
    A rod bearing includes the needles and the cages. Says you need 2 per rod. The wrist pin bearings come in packs of 200.
    Jim
    Mar 2023
    SW Florida
    i think he needs the mains the way he asked about outer race.
    Jun 2009
    Yes my bad for not saying main yes i am referring to the crankshaft to block bearings no the connecting rods in anyway
    Mar 2023
    SW Florida
    Expensive and not sold separately. You don’t wanna mix used bearings from another motor or mix bearings from another journal same motor. A lot of people say you don’t wanna run any old bearings. If crank comes out they say all new. I see near 100 bucks for 1 main in a 2.5.
    Jun 2009
    Thats what they say
    I think I got all the chubby needle bearings - I counted 44
    Mar 2023
    SW Florida
    You have the spacer-bearing holder. 22 to a side. So there should be 21 slots in each holder with 1 more roller between each holder. If 44 is correct number.
    Jun 2009
    It's not like the connecting rod to crank shaft cage where I can count the slots in the outer pieces
    Going to put it together see how it fits with the 44
    I counted 44 myself and thats how many I see in pictures on line for new bearings for sale
  1. 2.5L 260/280/300 Big Bearing Crankshaft
    By tripower in forum Misc. Parts and Accessories
    Last Post: 10-19-2020, 02:25 PM
  2. 200 HPDI Vmax Rod Bearing or Crankshaft Lower Bearing
    By sailnaked6842 in forum Technical Discussion
    Last Post: 08-21-2019, 01:48 PM
  3. bearing part numbers
    By Ajskennels in forum Technical Discussion
    Last Post: 04-15-2018, 03:24 PM
  4. 280 sporty fat shaft bearing numbers help
    By natemart94561 in forum Technical Discussion
    Last Post: 06-03-2015, 01:56 PM
  5. 280 Big Bearing Crankshaft
    By chris gantt in forum Misc. Parts and Accessories
    Last Post: 07-30-2014, 10:37 AM
