Results 1 to 5 of 5
05-24-2023, 01:08 PM #1
05-24-2023, 06:30 PM #2
This is maybe not the one you want, but the ad lists all kinds of alternate part numbers from other manufacturers.
https://www.discountstarterandaltern...oildyne-pumps/
05-25-2023, 12:17 PM #3
Merc doesn't make them anymore and the old ones that are still around are not very good. They replaced with a 2 wire unit that is still in production today. I would recommend one of those. ARCO makes them at a reasonable price and they are good units.
Going to 2 wire means you ditch the solenoids and put relays in instead. This is a much better system and will upgrade the motor to the current production unit. Its a little investment now but it will be worth while. Parts are easier to get and more reliable.
LakeFever liked this post
05-25-2023, 12:36 PM #4
This is the Arco Marine version of his stock pump apparently: https://arcomarine.com/products/6218
sonicss33 liked this post
08-01-2023, 10:15 AM #5
Mercury Tech: Wire gauge for mercury trim pump
By checkmate45 in forum Technical DiscussionReplies: 2Last Post: 06-30-2019, 03:58 PM -
Mercury Mariner Hydraulic Power Trim & Tilt Assembly 3 Ram 3 wire
By knothed in forum Misc. Parts and AccessoriesReplies: 0Last Post: 01-02-2018, 02:10 PM -
Mercury-Mariner-Power-Trim-amp-Tilt-Assembly-3-Ram-3-wire Mercury-Mariner-Power-Tri
By TopGunMarine in forum Ebay Listings and Other Internet ListingsReplies: 0Last Post: 12-20-2017, 10:09 AM -
Mercury power trim pump fresh water (3 wire)
By buelldave in forum Misc. Parts and AccessoriesReplies: 8Last Post: 01-23-2014, 07:17 PM
