Results 1 to 10 of 10
05-22-2023, 12:20 PM #1Junior Member
- Jan 2020
- lindenhurst ny
Hydrostream Voyager lower unit problems
Have 2004 Evinrude 250 with bobs low water pick up,Had the boat out yesterday running 65 mph plus,Motor has 136 hours,When I returned to the dock port side of lower where bobs nose cone connects had a quarter size piece of bondo that came off,Looks like water is comming out of the area bondo came out of.Any ideas?
05-22-2023, 12:29 PM #2
05-22-2023, 01:19 PM #3Junior Member
- Jan 2020
- lindenhurst ny
It looks like it was epoxied or bondoed after the cone was attached,Mind you this is about a quarter size piece that came off the middle of the lower unit at about the height that the cone attaches.I have pics but not sure how to attach.Thanks for the reply.
05-22-2023, 03:06 PM #4
05-23-2023, 06:46 AM #55000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
It isn’t welded on. Just gonna have to add filler. JB weld. No bondo. Bondo holds up pretty good to air at 70 mph. Water? Not so much…. Might want to find the seam between cone and the unit and V it out and re-epoxy the seam. This doesn’t have to look perfect. It has to hold it on.
05-23-2023, 07:30 AM #6Junior Member
- Jan 2020
- lindenhurst ny
Thanks for the responce,Doe's anyone favor one type of Epoxy over another,And yes the picture above with a small portion of epoxy,filler/ whatever looks similar to the debacle I got going on.
05-23-2023, 08:31 AM #7
OnPad liked this post
05-23-2023, 11:48 AM #85000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
JB Weld. Marine Tex. they both have a little filler in them to give it a paste consistency. maybe use shredded fibers in liquid epoxy. The other way to go is put a layer of glass mat over the nose one. But that makes it bigger, therefore slower.
05-24-2023, 08:47 AM #95000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
I had a similar issue with a coned OMC gearcase losing a quarter-sized piece and I repaired it with Marine Tex. Marine Tex is my go-to compound for these and other kinds of similar repairs on hulls and lowers. Has never let me down and you can shape it and sand it. Good stuff IMO.
05-25-2023, 06:57 PM #10
You will get lots of practice patching it I have never seen a nose cone case that didn't pop chunks out from time to time never in 30 years of performance boating
Lower unit install problems.
By shelbydriver1 in forum Technical DiscussionReplies: 14Last Post: 04-25-2010, 12:11 AM -
'98 Mercury 115 lower unit problems..........
By emmittman in forum Technical DiscussionReplies: 6Last Post: 09-20-2009, 02:20 PM -
OMC lower unit install problems
By zx1216 in forum Technical DiscussionReplies: 15Last Post: 05-05-2008, 03:10 PM -
Lower Unit Problems
By OWENS1 in forum Technical DiscussionReplies: 1Last Post: 07-24-2006, 01:46 PM -
lower unit problems
By Steven in forum Technical DiscussionReplies: 0Last Post: 07-27-2003, 08:20 PM
