Results 1 to 15 of 39
Thread: Boston Whaler 1965
05-21-2023, 06:18 AM #1
89LASER liked this post
05-21-2023, 07:45 AM #2
05-21-2023, 07:46 AM #3
05-21-2023, 08:19 AM #4
05-21-2023, 08:21 AM #5
05-21-2023, 08:27 AM #6
converting from sit-down to stand-up console
please follow this thread for the console build out --> https://www.screamandfly.com/showthr...nsole-upgrades
05-21-2023, 08:36 AM #7
05-21-2023, 08:47 AM #8
scrubbed the inside clean ..
the wood left on the flooring was screwed in , so after removing the screws, I glassed in the holes to prevent water from entering into foam core
the 5 inch square access that was made in the starboard rear was cut open to view the condition of the foam...luckily all is dry, the access was later glassed closed again
what helped in keeping the core dry is the original owner never kept the boat in the water thus no bottom paint and gelcoat is all original
05-22-2023, 05:13 AM #9
Scream And Fly VIP
- Sep 2002
- Venice, FL
- 378
- 22
- 59
- 184
Nice job! I have a BW Nauset 16'7" and retromod the motor.
05-22-2023, 07:08 AM #10
05-22-2023, 12:04 PM #11
Scream And Fly VIP
- Sep 2002
- Venice, FL
- 378
- 22
- 59
- 184
Have a pic of the motor, its a 1988 Yamaha 90hp under cover.
will post a couple more when I get it on the water.
05-22-2023, 04:18 PM #12
my 1975 16'7" with a buck and a half "tower of power" circa 1976....
05-22-2023, 06:46 PM #13
Glad you are sealing things up as you find them. Take a good looks at the thru hull fittings. I was very happy I replaced mine in my ‘75 11 footer. It was a dry boat, yet the brass thru hull fitting were corroded from the inside. Pretty common from what I gathered. Nice boat!
noli liked this post
05-23-2023, 06:35 PM #14
5000 RPM
- Sep 2017
- ontario
- 699
- 67
- 43
- 72
- 170
sometimes a simple reliable project is just allot of time well spent . Have fun Noli
05-24-2023, 02:30 PM #15
I'm a hog and currently working on 3 rebuilds, and the Whaler will not get completed if I don't concentrate on the Boston Whaler...which is what I will do, thus here are the latest
1. skater-24-like https://www.screamandfly.com/showthr...500wbd10122019
2. Hydrostream https://www.screamandfly.com/showthr...6032018/page12
Boston Whaler 13
By nelsoncat in forum General Boating DiscussionReplies: 18Last Post: 09-29-2011, 09:05 PM -
13 Boston Whaler pad???
By ecg101 in forum Technical DiscussionReplies: 9Last Post: 12-31-2008, 05:47 PM -
My winter project, 1965 Whaler
By blkmtrfan in forum General Boating DiscussionReplies: 32Last Post: 07-30-2007, 08:23 AM
