Results 1 to 4 of 4
    Jul 2018
    CORPUS CHRISTI TX
    Ignition trigger
    Het Guys,,I'm trying to figure out how to ohm test my after-market(blue) CDI ignition trigger(timer) 2000 225 Johnson looper,,,,,,what's the procedure & specs??
    May 2001
    Hickory NC
    Voltage test is much more reliable but you need a DVA/Peak reading meter.
    Jul 2018
    CORPUS CHRISTI TX
    Thanx Bud
    Jan 2020
    Pinole, Ca
    DVA on the 10 or 20 volt scale and test in between the legs of it. Should read voltage and they should all have the same voltage. Not sure the exact spec, but if they are all 5v or 15v or whatever then you are good. And test in both directions.
  1. Trigger
    By Bill H in forum Technical Discussion
    Last Post: 06-15-2004, 07:32 AM
