Results 1 to 15 of 15
05-15-2023, 04:09 AM #1New Member
- May 2023
- netherlands
Merc V6 2 stroke oil pump (alarm) question
The oil pump on the merc v6's (2 stroke) has an sensor attached to it.
Will the alarm sound if the gear is not rotating? Or also when no oil is deliverd to the pump?
What happens if you run the pump dry? Would the alarm also sound due to this sensor?
Offcourse the alarm will sound if the oil level in the tank under the cowling is low, but thats not the question here.
05-15-2023, 04:53 AM #2
tha pump has a "rotation sensor" thats tied into a switch box to get a signal.. lottsa folks have NO confidence in this part of tha warning... seems like its always too late by tha time it will alarm... if it alarms at all... there is no signal for oil movement and/or present...
JMO.. if ya know tha history of tha motor and if ya know its never been over heated then tha oiler is probably safe.. but if ya don't its a crap shoot.... heat is what kills tha crank gear.................Last edited by tlwjkw; 05-15-2023 at 05:02 AM.
rgsauger liked this post
05-15-2023, 08:35 AM #3New Member
- May 2023
- netherlands
Thnx bud,
Reason i ask is because my oiler alarm sounds at higher RPM (+3500rpm at speed). Weird because it started beeping 1 minute after i took in out of winter storage. I always add some oil to my fuel tank, just for the reason the pump fails, and a little bit extra oil never hurts. Never overheated on my watch.
05-15-2023, 11:03 AM #41980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
05-15-2023, 12:13 PM #5
could be a switch box actin' stupid OOOOOOOOOORRRRRRRRRRRRR time ta float test tha oiler stuff and go 'ole fashion and get out tha measurin' cup....
Dave Strong, rgsauger liked this post
05-15-2023, 01:55 PM #65000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
the oil alarm. it alarms me you wanna trust it in the first place... float test. former squid?
05-15-2023, 01:58 PM #7
kinda.. all my time was on PBR's.
rgsauger, pcrussell50 thanked for this postrgsauger, pcrussell50 liked this post
05-15-2023, 02:11 PM #85000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
Heart of Darkness. I was a Brown shoe. Flight deck of the Saratoga.
05-15-2023, 07:14 PM #9
know a little 'bout her.. she was a well used boat from what i remember...... that boat made tha rounds.. pretty sure a good friend in our bunch got orders to it when he got tired of what we were doin'.. wanted ta see what tha "regular" navy was all about.. think it was still in tha Med at that time... long, long time ago.............................
05-15-2023, 08:38 PM #10
Thank you both for your service. My dad is a retired USN full bird.
05-16-2023, 09:25 AM #116000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
A brother, im aPBR guy too, mekong riv, pbr and boston whaler patrol, 1970. brown water navy. 25;1 mix back then. good ole r. nixon
05-16-2023, 11:27 AM #12
damn, whoda thought it!!!.. what Section.?.. 521, started in tha delta '65/'66 ended up in I corp '(Hue river) 67/'69... didn't think you were that old!.. congrats bud.
05-16-2023, 03:18 PM #135000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
So do you ever look out at the riverbank and half expect to see sun glint off the barrel of an AK? I joined in 75. Biggest threat then was the shore patrol and weed sniffing dogs…
05-16-2023, 05:59 PM #14
not so much anymore thanks ta VA and mostly my latest (and last) wife........... my biggest problem was i liked it.
05-16-2023, 06:40 PM #155000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Years ago I had a beeping problem that was hard to get rid of and after the switchboxes were replaced it went away.
tlwjkw liked this post
Mercury Tech: Mercury 175 -2 stroke - carb -oil injection alarm
By trophyagamefishing in forum Technical DiscussionReplies: 23Last Post: 01-14-2018, 06:54 PM -
external oil pump delete help merc 2 stroke
By CauZey in forum Technical DiscussionReplies: 2Last Post: 04-04-2012, 07:16 PM -
Merc 4 Stroke question (ouch)
By MAJOR HAVOC in forum General Boating DiscussionReplies: 4Last Post: 05-02-2003, 04:05 PM -
merc fuel separator water alarm question
By FrankAR in forum Technical DiscussionReplies: 1Last Post: 03-29-2003, 12:48 PM -
question on a Merc 25hp (2-stroke)
By Casey in forum Technical DiscussionReplies: 7Last Post: 02-22-2003, 01:33 PM
