Results 1 to 11 of 11
Thread: Help Diagnosing Starter Issue
05-11-2023, 08:13 AM #15000 RPM
- Jun 2013
- Venezuela
- 190
- 13
I have a 225 Mercury Optimax that is having an intermittent starting issue.
When you try to start it, the system will click repeatedly and never crank the engine. As if there was a faulty connection somewhere. Then sometimes it will start normally with not issues.
If I hotwire the starter at the engine with a screwdriver, it will always start with no issues so I'm guessing the issue might be somewhere along the cables going to the starter switch.
Is it possible to test at the harness level so I can confirm the issue is in the cabling going to the switch instead of the engine?
Here's a video of the issue:
https://www.dropbox.com/s/bq16yf1tb1...%20AM.mp4?dl=0
05-11-2023, 12:22 PM #2
Bad starter solenoid
pcrussell50, CptAJ thanked for this post
05-11-2023, 03:57 PM #35000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
what he said. cheap. easy to change.
CptAJ, pcrussell50 thanked for this postrgsauger, pcrussell50 liked this post
05-13-2023, 10:43 AM #45000 RPM
- Jun 2013
- Venezuela
- 190
- 13
That seems to have been the issue. I replaced it with another one I had from my old EFI and so far the issue hasn't come up.
Thanks a bunch, guys. It seems obvious in retrospect but I was stuck overthinking it XD
05-29-2023, 08:15 AM #55000 RPM
- Jun 2013
- Venezuela
- 190
- 13
Welp, looks like we just got lucky for a few days with the new solenoid cause the issue is back (Dont you just hate intermittent problems?)
Anyone got any ideas as to what else it could be?
05-29-2023, 08:22 AM #6
internal corrosion in battery cable..just dealt with it a couple days ago
RockTeam Junk
06-12-2023, 07:02 AM #75000 RPM
- Jun 2013
- Venezuela
- 190
- 13
06-13-2023, 07:15 AM #8
Id run a continuity test on the yellow / red wire. Don't rule out the key switch either. Should be fairly simple to trace it sown now.
www.InjectorService.com
Call/Text - 204-326-0390
06-13-2023, 07:20 AM #95000 RPM
- Aug 2019
- Palmharbor
- 558
- 20
- 58
- 150
Take the old fashion load tester to it check the amperage compared to the battery directly
06-13-2023, 08:11 AM #10Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
I just had the key switch gremlin. Thought it was the solonoid.
06-13-2023, 07:05 PM #115000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
If the problem is before the solenoid in the low amp circuit the solenoid will not click. If you hear solenoid click, it is either the solenoid or battery cable-connector issue. The batt cable can give enough 12 volts to run everything in the boat but not pass enough amps to fire the starter. But most likely culprit will be the solenoid.
Mercury Tech: Diagnosing bad cylinder
By Silvershiner in forum Technical DiscussionReplies: 8Last Post: 10-15-2018, 08:55 AM -
Mercury Tech: Diagnosing sick 2.5 260
By n.jimenez0101 in forum Technical DiscussionReplies: 25Last Post: 07-26-2018, 11:06 AM -
Help diagnosing 1995 2.5
By wfowahoo in forum Technical DiscussionReplies: 4Last Post: 12-15-2016, 06:51 AM -
Issue with starter not shutting off while crankin motor
By Swamp boy in forum Technical DiscussionReplies: 2Last Post: 06-14-2011, 05:48 PM -
Help Diagnosing
By Hydrostream200 in forum Technical DiscussionReplies: 7Last Post: 07-10-2008, 01:51 PM
