Results 1 to 3 of 3
Thread: Is this crank case rebuildable
05-07-2023, 10:00 PM #1New Member
- May 2023
- SOUTH CAROLINA
Guys I've been lurking here for a good while but I have an issue I'd like to post on and see what y'all think. I'm very mechanical but it's more guns and farm equipment for me. I bought a used block and crank for my 50 2 stroke Yamaha. I'd like to rebuild that block then install it in my motor. Then rebuild the one in the motor and keep it for a spare.
What happened is the top bearing on the crank went out and then spun in the housing. So I'm wondering if the crankcase can still be used with the damage the bearing did when it spun? Or if that can somehow be repaired. Or if I need to junk the block and find another one? I'm planning on running it over to Jeff Dunn in Conway for him to look at but just wondering what you guys think.
I
05-07-2023, 10:05 PM #2New Member
- May 2023
- SOUTH CAROLINA
Here is another pic.
05-26-2023, 05:49 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
It could be..... but easyer to find better......I see no Damage to the next main web.......so bad crank/bearings?
By Turpentine2 in forum Technical DiscussionReplies: 0Last Post: 05-07-2023, 09:33 PM -
Crank case pressure
By tinker060 in forum Technical DiscussionReplies: 14Last Post: 07-15-2007, 01:01 PM -
Sealing crank case
By ProComp in forum Technical DiscussionReplies: 4Last Post: 05-28-2003, 10:42 PM -
Crank case halves...
By Reese in forum Technical DiscussionReplies: 4Last Post: 03-12-2003, 10:30 PM -
Crank case pressure
By CNT in forum Technical DiscussionReplies: 2Last Post: 07-03-2002, 11:47 AM
