Results 1 to 4 of 4
05-04-2023, 12:26 AM #1
5000 RPM
- May 2014
- WI
- 125
- 15
- 57
- 60
10" Bob's Jackplate & SeaStar Pro Steering $600
Bob's Machine Shop Flats jack plate with pump and SeaStar Pro hydraulic steering system with blinker trim and wheel. All of these parts came rigged on a hull I bought. Full disclosure, previous owner was in NJ, so these have been in saltwater. Antiseize was used generously by previous owner on all the hardware, so everything came apart without hassle.
10" Jackplate $650: I took it apart before mounting my engine on it (June 2022) to clean it up with parts washer machine. All the old grease was cleaned out and I ran taps through all threaded holes to clear out any remaining corrosion build up. New SS hardware installed everywhere with antiseize. I replaced the shear pin bolt at top of the ram with a grade 8 bolt. I have one full season of use with it (85 hrs), and had no problems running a 300R on it.
SeaStar Steering $600: This is a 2.0cu in Pro steering system with 20' lines, dual blinker trim, with 13" steering wheel and red anodized spacer. I have not tested this complete system under load (was functional on trailer). Just needs brackets and pin to mount to tilt tube
Located in Fond du Lac, WI. Will ship at buyers expense.
05-22-2023, 03:44 AM #2
Junior Member
- Jun 2003
- Watertown, WI
- 29
PM Sent
05-22-2023, 10:17 AM #3
5000 RPM
- May 2014
- WI
- 125
- 15
- 57
- 60
Steering system sold, jackplate still available
05-25-2023, 10:01 PM #4
Pm sent!
19' STV euro
24' Baja 232
22' Talon with 670hp sold
22' Baja Hammer sold
25' Talon sold
19' euroski sold
22' Talon sold
21' skater sold
21' cougar MTR sold
21' talon sold
SeaStar JP5040R Hydraulic Jackplate 4" Almost new!
By freeride99 in forum Misc. Parts and AccessoriesReplies: 3Last Post: 03-30-2023, 09:55 AM -
Seastar Pro VS "regular" Seastar steering
By phaster in forum Technical DiscussionReplies: 22Last Post: 11-11-2022, 06:27 AM -
Is there a "tension" adjustmant on seastar steering
By CircleHook in forum Technical DiscussionReplies: 1Last Post: 08-06-2018, 11:19 AM
