Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 50 of 50
  1. #46
    Jul 2017
    upstate ny
    well...I still have popcorn left...
    2 stroke every time I can..don't like boating with my lawn mower
  2. #47
    Poor CRAP cake, he has to make stuff up as he goes.
    You have to live two life's. Your pathetic one, and your illusion of mine ..
    Yes , stainless fasteners are fine. Matter of fact all new marine engines come with them.
  3. #48
    May 2009
    Quote Originally Posted by rudderless View Post
    I don’t need any, anymore.
    My take on the situation as of now is:
    -for rod bolts? Proper high strength bolts. No homebrew hacks, not negotiable.
    -for outboard heads? High strength bolts not called for. In fact, the kind of torques required to achieve preload on a high strength bolts might be very hard on aluminium threads. There is room here for homebrew hacks… As long as you have valid data as to what torque to use to achieve proper preload… Or else are an experienced marine mechanic and you know what works from, well, experience. I have book smarts, (engineering degree), but I am not an experienced marine mechanic, which is why I’m here to sponge information off of you lot.
    That about sum it up?
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
  4. Likes tlwjkw, loop liked this post
  5. #49
    Yes Peter, that about sums it up. You school boy's design and make it.
    Us ole country bumpkins, show ya how ta use it, fix it, make it better ...
  6. #50
    Jun 2018
    Floating around
    Just use good clean oem bolts and make sure all the threads are clean. Refer to merc manual for lube and torque spec guidance. Done
    I read it as wanting to swap from stock to aftermarket stainless which i would never do, ever. As for steel bolts not stretching in aluminum blocks? Better not run and LS/LT motors. Those head bolts are torque to yield and stretch right out.
  1. insuring against stuck bolts? torquing head bolts with marine grease?
    By pcrussell50 in forum Technical Discussion
    Last Post: 07-21-2015, 10:55 AM
  2. Mercury Tech: Wtb stainless head bolts or studs for a 260
    By jas638 in forum Technical Discussion
    Last Post: 01-31-2013, 08:06 AM
  3. Opinions on Stainless Head Bolts...
    By rockman69 in forum Technical Discussion
    Last Post: 01-15-2009, 08:25 PM
  4. Stainless steel head bolts?
    By PhastBoat in forum General Boating Discussion
    Last Post: 11-23-2003, 10:56 PM
