Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 50
    Mar 2023
    SW Florida
    any reason not to use stainless head bolts in outboards?
    they are plain jane steel. i think a little better than home depot quality, but still just steel bolts. i know a busted stainless bolt is way harder to get out, but odds of one snapping i think would be a lot lower. i posted in the for sale section by accident. so deleted and moved it here.
    MIAMI FLORIDA
    Not really except in places like head bolts/main case bolts where torque/bolt strenth matters... if you want stainless there you need to go with ARP. Brush the theads on all bolts with gasket sealing compound and they will usuall come right out even on the gearcase/water pump.
  3. Likes rgsauger, loop liked this post
    Jul 2021
    Pompano Beach
    Stainless will weld itself into an aluminum block. 2 dissimilar metals.
  5. Thanks KIRCHNER thanked for this post
    Likes sharpeye Mike, OnPad, loop liked this post
    Houston, TX
    Quote Originally Posted by Capt j View Post
    even with antiseize?
    MIAMI FLORIDA
    Salt is the issue we have not galvanic corrosion, you cant get the bolt out if the heads rusted off either. The sealnt on threads cures both of those problems anyway...
    Sep 2008
    charlestown, ri
    in my view stainless is they way to go for head screws and powerhead / adapter mounting screws. obviously with sealant. its the shoulder that gets crusty and seizes anyway, not the threads in 90% of cases. i wonder if fully threaded screws would actually be better, or would that compromise stability somehow?
    Feb 2022
    Other than the obvious issues that will occur with SS in aluminum, you may have to retorque a few times. I dont believe SS bolts will stretch when torqued. This stretch that head bolts do is to compensate for the heating and cooling and casket compression. This is just my opinion, coming from small engine repair education from 30 years ago.
    Mar 2023
    SW Florida
    so the consensus is stay with grade 5 steel?
    Jun 2018
    Floating around
    Critical fasteners all need to be carbon steel and they need to be torqued properly for the right amount of stretch. Stainless is gummy and doesnt have much carbon so this is why stainless is not used for critical fasteners. Stock bolts are best. Search out jsre member on here who offers the best advice on bolts and torque specs what lube to use etc
  12. Likes CUDA, OnPad liked this post
    MIAMI FLORIDA
    Yea go with steel... factory steel fasteners are best especially around salt water and make sure you get that torque wrench calibrated for the proper bolt stretch.
  14. Likes loop liked this post
    Nov 2009
    hardyville va
    [QUOTE=H2OPERF;3387328]Yea go with steel... factory steel fasteners are best especially around salt water and make sure you get that torque wrench calibrated for the proper bolt stretch.[/QUOTE Half the outboards in production use stainless for headbolts as well as for most of the fasteners on the motor. Put steel bolts in a lower unit, or water pump housing and see how that goes.
  16. Likes rgsauger liked this post
    Jun 2009
    Bristol, Connecticut
    Steel head bolts non merc do they stretch? What about titanium bolts?
  18. #13
    Mar 2023
    SW Florida
    i don't think any steel bolt stretches when it is 5/16 or 3/8 and bolted into aluminum. i think you will stretch the threads outta the aluminum first...
  19. Likes loop liked this post
  20. #14
    Jun 2009
    Quote Originally Posted by derekfl View Post
    OK but do the steel bolts need to stretch because the aluminum heads heats up or is the stretch only for the initial torque, and since the steel doesnt stretch is that ok?, I might try steel or titanium bolts in some longer thermostat bolts...
    And merc 3.0 liter head bolts arnt stainless ???
  21. #15
    Central Florida
    That isn't correct. If any metal bolt is torqued or loaded at all, it is stretching. How much torque or load will determine how much elastic stretch, if it yields, breaks, or fails the threads in the block.
  1. insuring against stuck bolts? torquing head bolts with marine grease?
    By pcrussell50 in forum Technical Discussion
    Last Post: 07-21-2015, 10:55 AM
  2. Mercury Tech: Wtb stainless head bolts or studs for a 260
    By jas638 in forum Technical Discussion
    Last Post: 01-31-2013, 08:06 AM
  3. Opinions on Stainless Head Bolts...
    By rockman69 in forum Technical Discussion
    Last Post: 01-15-2009, 08:25 PM
  4. Stainless steel head bolts?
    By PhastBoat in forum General Boating Discussion
    Last Post: 11-23-2003, 10:56 PM
