Results 1 to 15 of 50
04-30-2023, 01:42 PM #15000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
any reason not to use stainless head bolts in outboards?
they are plain jane steel. i think a little better than home depot quality, but still just steel bolts. i know a busted stainless bolt is way harder to get out, but odds of one snapping i think would be a lot lower. i posted in the for sale section by accident. so deleted and moved it here.
04-30-2023, 05:57 PM #2
Not really except in places like head bolts/main case bolts where torque/bolt strenth matters... if you want stainless there you need to go with ARP. Brush the theads on all bolts with gasket sealing compound and they will usuall come right out even on the gearcase/water pump.
04-30-2023, 11:25 PM #35000 RPM
- Jul 2021
- Pompano Beach
- 144
- 16
- 38
Stainless will weld itself into an aluminum block. 2 dissimilar metals.
KIRCHNER thanked for this post
05-01-2023, 12:04 AM #4
05-01-2023, 06:02 AM #5
Salt is the issue we have not galvanic corrosion, you cant get the bolt out if the heads rusted off either. The sealnt on threads cures both of those problems anyway...
05-02-2023, 10:30 PM #65000 RPM
- Sep 2008
- charlestown, ri
- 296
- 10
- 37
in my view stainless is they way to go for head screws and powerhead / adapter mounting screws. obviously with sealant. its the shoulder that gets crusty and seizes anyway, not the threads in 90% of cases. i wonder if fully threaded screws would actually be better, or would that compromise stability somehow?
05-03-2023, 03:42 AM #7
Other than the obvious issues that will occur with SS in aluminum, you may have to retorque a few times. I dont believe SS bolts will stretch when torqued. This stretch that head bolts do is to compensate for the heating and cooling and casket compression. This is just my opinion, coming from small engine repair education from 30 years ago.
05-03-2023, 07:55 AM #85000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
so the consensus is stay with grade 5 steel?
05-03-2023, 08:08 AM #9
Critical fasteners all need to be carbon steel and they need to be torqued properly for the right amount of stretch. Stainless is gummy and doesnt have much carbon so this is why stainless is not used for critical fasteners. Stock bolts are best. Search out jsre member on here who offers the best advice on bolts and torque specs what lube to use etc
05-03-2023, 08:54 AM #10
Yea go with steel... factory steel fasteners are best especially around salt water and make sure you get that torque wrench calibrated for the proper bolt stretch.
loop liked this post
05-05-2023, 02:49 PM #115000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
[QUOTE=H2OPERF;3387328]Yea go with steel... factory steel fasteners are best especially around salt water and make sure you get that torque wrench calibrated for the proper bolt stretch.[/QUOTE Half the outboards in production use stainless for headbolts as well as for most of the fasteners on the motor. Put steel bolts in a lower unit, or water pump housing and see how that goes.
rgsauger liked this post
05-22-2023, 02:30 PM #12
Steel head bolts non merc do they stretch? What about titanium bolts?
05-22-2023, 06:39 PM #135000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
i don't think any steel bolt stretches when it is 5/16 or 3/8 and bolted into aluminum. i think you will stretch the threads outta the aluminum first...
05-22-2023, 07:26 PM #14
OK but do the steel bolts need to stretch because the aluminum heads heats up or is the stretch only for the initial torque, and since the steel doesnt stretch is that ok?, I might try steel or titanium bolts in some longer thermostat bolts...
And merc 3.0 liter head bolts arnt stainless ???
05-22-2023, 07:28 PM #157000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
insuring against stuck bolts? torquing head bolts with marine grease?
By pcrussell50 in forum Technical DiscussionReplies: 26Last Post: 07-21-2015, 10:55 AM -
Mercury Tech: Wtb stainless head bolts or studs for a 260
By jas638 in forum Technical DiscussionReplies: 6Last Post: 01-31-2013, 08:06 AM -
Opinions on Stainless Head Bolts...
By rockman69 in forum Technical DiscussionReplies: 9Last Post: 01-15-2009, 08:25 PM -
Stainless steel head bolts?
By PhastBoat in forum General Boating DiscussionReplies: 16Last Post: 11-23-2003, 10:56 PM
