Results 1 to 2 of 2
Thread: 225 ProMax 15" mid, CLE 3 hole
04-28-2023, 06:17 PM #1Team Member
- Feb 2017
- Indiana
- 34
- 16
- 16
- 9
SOLD pending funds
Merc ProMax 225 rebuilt winter of 2020 with 60 hrs currently. I added 10 hours during past two seasons and sold the STV hull this was on.
$9,000
Replaced green merc graphics with stock colors. Included picture of old decals because it is a good picture of the midsection.
- The engine has been completely rebuilt. Machine work performed by James Perry.
- Block was bored .015 over and decked.
- Oiler gear has been gone but James filled the void in the block.
- WSM 1.5 MM ring Pistons, ring gaps measured .019 - .021, all new bearings, steel caged rod bearings, gaskets.
- CCM reeds on lapped cages. An extra set of TDR reeds will be included.
- Heads were machined and measured to 36cc by JSRE.
- VST has been deleted, replaced by a Bosch 044 remote fuel pump, an Aeromotive regulator, and two Aeromotive in-line filters. The pre pump filter is 100 micron and the after is 10 micron.
- All AN fittings and ethanol resistant hose.
- David Dreifort butterfly throttle linkage upgrade.
- New trigger, stator, regulators, and switch boxes.
- Lighter weight flex flywheel. You will also get the heavy flywheel as well.
- A new Brucato ECU with 225 ProMax fuel curve and a 7200 limiter.
- New NGK plug wires
- OEM lightweight Alien Cowl and pan are in excellent shape. Skirt has a small crack that was repaired you can hardly see from a few feet away.
Drag4 30” not included but available at a discount with motor purchase.Last edited by Jkissel20; 05-06-2023 at 05:07 PM.
STV Pro Comp, 225 Promax
Allison GS 225 ProMax. Sold
Advantage Banshee e-tech 300 w/ Sport master. Sold
seychellesboy liked this post
05-03-2023, 09:36 PM #2Member
- Aug 2012
- Hebron,Kentucky
- 52
PM Sent.
Punched a hole in my Promax
By Jared A in forum Technical DiscussionReplies: 3Last Post: 04-05-2019, 02:36 PM -
98 300 promax 4 hole butterfly injection
By Varmint in forum Technical DiscussionReplies: 5Last Post: 10-27-2017, 04:52 PM -
15" 2 Hole CLE Lower, 15" 4 Hole Lower, 25" 2 Hole Lower, CLE Case - Cleaning House.
By Pachanga_rick in forum Lower UnitsReplies: 9Last Post: 09-11-2015, 04:48 PM -
24p Trophy, 225 Promax and 19.5 bassboat...zero hole shot
By Fast4wrd in forum Technical DiscussionReplies: 9Last Post: 08-24-2003, 11:08 PM
