Results 1 to 6 of 6
    Sep 2004
    Evinrude Standard 20” RH Lower Unit
    Clean used lower unit 20” Click image for larger version.
ID:	517645Click image for larger version.
ID:	517646Standard OMC $1250 plus ride
    will need impeller and oil service before putting back to work.
    Eastern PA
    What motor did this come from? Trying to determine if it will go on my motor which is a 1984 235…? Thank you
    Sep 2004
    I guess I was mistaken about the lower unit being a standard series, was told by another scream and fly guy that the lower unit was actually a gen I magnum with the low water pickup holes in the nose. Live and learn I guess. He suggested it should bring more that what I have it listed for, but I’m not going to change the asking price, maybe just let someone gat a little better deal.
    Sep 2004
    Sorry missed your question, lower unit came from I can remember for sure but think it was 2005/06 225
    Eastern PA
    Thanks. No problem. I don’t think it will fit my old motor. Nice piece, regardless.
    Sep 2004
    Actually the local shop tells me it will fit if you swap out the drive shaft. You might check with your mechanic.
  1. Standard production lower unit
    By Go Time in forum Parts Wanted
    Last Post: 03-17-2017, 09:26 AM
  2. WTB: 2.4 Lower Unit 1.87 Standard Rotation
    By VLP in forum Lower Units
    Last Post: 07-21-2016, 08:34 AM
  3. OMC Tech: Lightning lower unit and standard 2006 250 etec
    By bwonder in forum Technical Discussion
    Last Post: 05-27-2011, 05:54 AM
