Results 1 to 5 of 5
Thread: reading piston tops 2.5 carb
04-01-2023, 07:48 PM #15000 RPM
- Nov 2013
- palatka fl
- 117
guys 1993 2.5 200hp carbs v6 after rebuild and break in im reading spark plugs and piston tops basic question is should they be clean looking or oiley and little black with carbs all adjusted no 2 piston shows up clean all other 5 are oiley and clean carbs are 11/2 turns out is no 2 too lean on that carb not sure here thanks for advice
04-01-2023, 08:46 PM #2
"Clean" is rich... the piston is too cool to burn the oil, so the gas just "washes" it off and no carbon builds up.
But, unless you have 20 hears of doing it daily, you can really only "read" the pistons after running wide-open and killing the ignition as soon as it's safe... not after idling up to the dock or onto the trailer.
rgsauger liked this post
04-01-2023, 08:58 PM #35000 RPM
- Nov 2013
- palatka fl
- 117
david can you suggest a safe setting on all carbs and then do a high rpm shut off this stuff is all new rebuilt dont want to burn also could the colder water be an issue and running no stats im running a gutted out stat
David - WI liked this post
04-01-2023, 09:10 PM #4
I have no idea what your carbs need. You would have to check the service manual for your year & model. It usually depends on air temperature & elevation.
04-01-2023, 09:13 PM #5
I have no idea what your carbs need, my 2.5 is EFI. You would have to check the service manual for your year & model. It usually depends on air temperature & elevation.
Polishing heads and piston tops?
By olboatman in forum Technical DiscussionReplies: 7Last Post: 12-17-2014, 09:52 AM -
carbon on piston tops
By daytrader in forum Technical DiscussionReplies: 7Last Post: 06-21-2013, 02:31 PM -
Piston tops....
By macutty in forum Technical DiscussionReplies: 3Last Post: 08-13-2008, 06:55 AM -
Piston tops, what do i look for if to lean?
By FAST-J in forum Technical DiscussionReplies: 13Last Post: 04-24-2007, 04:29 PM -
Reading piston tops ??
By Dingie in forum Technical DiscussionReplies: 0Last Post: 06-20-2005, 07:15 AM
