Results 1 to 15 of 22
    Mar 2021
    42 waterford dr, Englewood fl 34223
    2.5 EFI's sputtering
    Something new, 2.5 EFI's 280 hp 7,500 RPM. done over by Diamond Marine. Motors idle and run smooth up to 5,000 + RPM then they start sputtering. Out of the hole their fine. Cruise all day at 4k. Mercury racing 2 cycle @ 30-1, 93 octane with new fuel filters. What gives?
    Jun 2018
    Floating around
    Could be a pile of things. Unless someone here knows some secret sauce about this specific mota you need to verify a few things. Id be looking at fuel pressure for starters it could be the fuel pump going out. If that all checks out then id be moving onto electrical. Spark test, stator test, ecm grounds, grounds in general would be a wise thing to go over now. For the laser stuff iirc Merc has a service bulletin to add a ground to the brain chassis to the block. Maybe applies to yours i dont know much about the digital efi stuff. Others will chime in im sure
  3. Likes rgsauger liked this post
    Mar 2021
    Im about to put some load on the motors to try and learn more. My first thought is some of the coils may be starting to break down. Runs well at lower RPM but not high.
    Mar 2022
    Lake Travis Texas
    Problems on new engines frequently are in the boat. Make sure your fuel system is right. Check to see if you have a anti syphon valve on tank. Check or replace fuel hoses. Monitor primer bulb ensuring it does not collapse at speed.
    Loading an engine that is not running properly is not something I would suggest. Your assuming its electrical. It may be but if its fuel you can damage the engine.
    Jim
    Jun 2018
    Floating around
    Agreed new fuel hoses is a great start. Replace em
    all its cheap and then you know.
    Quote Originally Posted by Jim Speros View Post
    280 with a primer bulb??
    Have you tried replacing the plugs?
  9. #8
    Mar 2022
    Lake Travis Texas
    Dave, You got me. I'm geezin.
    Jim
  10. Likes Dave Strong liked this post
    shreveport,la
    First thing I’d do is send the injectors out to somebody reputable to get them checked out. Second I would replace any fuel filters and check the free flowing ability of your fuel pump(s) to pump fuel. If I remember correct you’re looking for a gallon around 45 seconds. I’d do all this before I ran the engines anymore, especially under an excessive load. Once you ensure all this is up to snuff then you can continue with more diagnostic work but this will prevent you from hurting the engines from running lean
    Erik Kiser
  12. Likes tlwjkw, tux974, rgsauger, 97 TWISTER, LakeFever liked this post
    Houston, TX
    Yeah, lean sucks. $ucks!
  14. Likes LakeFever liked this post
    Jul 2022
    WI
    Quote Originally Posted by patchesII View Post
    Where is the best place to send injectors these days?
  16. #12
    Mar 2021
    Yea im not going to try a 125 lick. Ive got a buddy with a lap top and all the mercury software. Hes just busy so im on hold
    shreveport,la
    Quote Originally Posted by Voodoo1 View Post
    http://www.injector911.com/
    Trae is honest, highly competent and knows these engines up, down and backwards.
    Erik Kiser
  18. #14
    Jul 2022
    WI
    Thx!
  19. #15
    Jun 2018
    Floating around
    Also a site sponsor here
    https://injectorservice.com/
  1. OMC Tech: 2000 Evinrude ficht 175SSV sputtering,popping 1500-3300rpm,perfect start,idle,wot
    By herbzachry in forum Technical Discussion
    Last Post: 06-20-2014, 01:56 PM
  2. Sputtering '89 Merc 200
    By captwalleye89 in forum Technical Discussion
    Last Post: 03-22-2008, 11:31 AM
